Run the DPT SCSI Storage Manager Utility, DPTMGR, under DOS, and select Solaris as the operating environment. See Chapter 4 of DPT SmartCache III User's Manual for instructions. An error message similar to this may be displayed while DPTMGR is running.
Unable to find any drivers in the DRIVERS Directory ...... |
This message can be ignored.
When using the ECU supplied by DPT in conjunction with a configuration file, you enter emulation information as part of the configuration process. When you configure two drives, both should be "disabled." When asked for drive types for drives 0 and 1, type 0. This indicates "no drives present" and disables the WD1003 emulation mode of the adapter, allowing correct operation of the native mode driver.
