システム設定情報を表示するには、prtconf コマンドを使用してください。
# /usr/sbin/prtconf |
疑似デバイス、ロード可能なモジュール、および指定のカーネルパラメータを含むシステム設定情報を表示するには、sysdef コマンドを使用してください。
# /usr/sbin/sysdef |
次の prtconf 出力は、SPARC システム上で表示されます。
# prtconf
System Configuration: Sun Microsystems sun4c
Memory size: 32 Megabytes
System Peripherals (Software Nodes):
SUNW,Sun 4_50
packages (driver not attached)
disk-label (driver not attached)
deblocker (driver not attached)
obp-tftp (driver not attached)
options, instance #0
aliases (driver not attached)
openprom (driver not attached)
zs, instance #0
zs, instance #1
audio (driver not attached)
eeprom (driver not attached)
counter-timer (driver not attached)
memory-error (driver not attached)
interrupt-enable (driver not attached)
auxiliary-io (driver not attached)
sbus, instance #0
dma, instance #0
esp, instance #0
sd (driver not attached)
st (driver not attached)
sd, instance #0 (driver not attached)
sd, instance #1 (driver not attached)
sd, instance #2 (driver not attached)
sd, instance #3
sd, instance #4 (driver not attached)
sd, instance #5 (driver not attached)
sd, instance #6
x86 システムからは、次の sysdef 出力が表示されます。
# sysdef * Hostid * 29f10b4d * * i86pc Configuration * * * Devices * +boot (driver not attached) memory (driver not attached) aliases (driver not attached) chosen (driver not attached) i86pc-memory (driver not attached) i86pc-mmu (driver not attached) openprom (driver not attached) options, instance #0 packages (driver not attached) delayed-writes (driver not attached) itu-props (driver not attached) isa, instance #0 motherboard (driver not attached) pnpADP,1542, instance #0 asy, instance #0 asy, instance #1 lp, instance #0 (driver not attached) fdc, instance #0 fd, instance #0 fd, instance #1 (driver not attached) kd (driver not attached) kdmouse (driver not attached) . . . |
