The MIF database functionality for the SEA includes the following:
There is one MIF database associated with the SP. Each component has a MIF file to describe its manageable characteristics. When the component is initially installed into the system, the MIF is added to the MIF database. SP controls all access to the MIF database.
No MIF modification mechanism the to MIF database is provided. If the MIF needs to change, it must be uninstalled and modified using regular text editor tools, and then installed again.
Upon installation and removal of a MIF from the MIF database, the SP must issue an indication to all registered management applications.
