If you display the 7 Solaris information files (listed in Step 2) that are included in the SUNWrdm packages and installed in the /usr/share/release_info/Solaris_2.7/locale directory, you can only view them in English even though you logged in using the European locale.
Select Information from the front panel's Help menu.
Double-click the Solaris_2.7 folder in the Application Manager.
The following 7 Solaris Information files are displayed:
documentation_issues
driverupdate
eof
installation_bugs
new_features
patches
runtime_bugs
Double-click on each file.
It displays each file in dtpad.
Workaround: Go to /usr/share/release_info/Solaris_2.7/locale and use vi or dtpad.
