The Patch Analyzer performs an analysis on your system to determine which (if any) patches will be removed by upgrading to the Solaris 7 11/99 operating environment. The Patch Analyzer is available as a script to run manually and as part of the Interactive installation method.
If you are using the Interactive installation method to upgrade, choose the Analyze option to perform the analysis.
If you are not using the Interactive installation method to upgrade, use the steps below to perform the analysis using the analyze_patches script.
After performing the analysis, refer to "Reviewing the Patch Analyzer Output" for detailed information about the patch analysis results.
To run the analyze_patches script, the installed system and the Solaris 7 11/99 CD (or net image) must be accessible by the script either through an NFSTM mount or by using locally mounted media.
Change directories to the Misc directory on the OS image.
If the image is on locally mounted media on a SPARC system, type:
# cd /cdrom/sol_7_1199_sparc/s0/Solaris_2.7/Misc |
If the image is on locally mounted media on an x86-based system, type:
# cd /cdrom/sol_7_1199_x86/s2/Solaris_2.7/Misc |
If the image is available through an NFS mount, type:
# cd /NFS_mount_directory/Solaris_2.7/Misc |
Run the analyze_patches script:
# ./analyze_patches |
The options listed in Table 3-1 can be used on the command line.
Table 3-1 Command-Line Options for analyze_patches|
Option |
Description |
-R rootdir |
rootdir is the root of the installed system. It defaults to /. |
-N netdir |
netdir is the path to the root of the OS image to be installed. It defaults to /cdrom/cdrom0. It should point to the directory containing the Solaris_2.7 directory. You must use this option if running the patch_analyzer from an NFS mount. |
-D databasedir |
If the script is invoked from a directory other than the /Misc directory on the OS image, the program will not find the database it uses for patch analysis. Use the -D option to supply the path to the database. Without this database, contained in the /Solaris_2.7/Misc/database on the OS image, the script will not work properly. |
After performing the analysis, use these steps to review the output.
Review the output of the analyze_patches script.
The Patch Analyzer provides a list of patches that will be removed, downgraded, accumulated, or obsoleted by other patches. Patch accumulations are similar to patch upgrades. The accumulated patch is removed and its fixes are delivered by a new patch. Messages like the following are shown:
Patch 105644-03 will be removed. Patch 105925 will be downgraded from -02 to -01. Patch 105776-01 will be accumulated/obsoleted by patch 105181-05. |
If the Patch Analyzer program does not provide a list, no action will be taken against any patches previously installed on your system.
Decide if patch replacements and deletions are acceptable.
If the patch replacements and deletions by the Solaris 7 11/99 operating environment are acceptable, refer to "Upgrading a System" in the Solaris 7 (SPARC Platform Edition) Installation Library or the Solaris 7 (Intel Platform Edition) Installation Library to upgrade to the Solaris 7 11/99 operating environment.
If the patch replacements and deletions by the Solaris 7 11/99 operating environment are not acceptable, do not upgrade using the Solaris 7 11/99 CD. You may use the Solaris 7 MU4 CD and Solaris 7 Maintenance Update 4 Release Notes to install the patches on your Solaris 7 system.
During an upgrade, you may receive an informational message regarding some of the packages (including SUNWolrte, SUNWoldcv, SUNWoldte, SUNWolaud). No action is required.
An example of this message is:
Doing pkgadd of SUNWolrte to /
This message indicates an attempt to install the same architecture and version of a package that is already installed.
Installation of SUNWolrte was successful...
If you are running Solstice AdminSuite 2.3 software and you want to add OS services to your server, you need to install Solstice AdminSuite 2.3 patch: number 104468-11 (SPARC) or 104469-11 (Intel) or any subsequent revision of this patch. See "AdminSuite Patch Required for Installation or Upgrade" for more information.
