By writing your own shell scripts and using the commands shown in the following table, you can easily set up and manage your diskless client environment.
Table 7–3 Diskless Client Commands|
Command |
Subcommand |
Task |
/usr/sadm/bin/smosservice |
add |
Add OS services |
delete |
Delete OS services |
list |
List OS services |
patch |
Manage OS service patches |
/usr/sadm/bin/smdiskless |
add |
Add a diskless client to an OS server |
delete |
Delete a diskless client from an OS server |
list |
List the diskless clients on an OS server |
modify |
Modify the attributes of a diskless client |
You can obtain help on these commands in two ways:
Use the -h option when you type the command, subcommand, and required options. For example, to display the usage statement for smdiskless add type the following:
% /usr/sadm/bin/smdiskless add -p my-password -u my-user-name -- -h |
View the smdiskless(1M) or smosservice(1M) man pages.
