System Administration Guide: IP Services
Deleting IP Addresses from DHCP Service
You should delete IP addresses from the DHCP service database if you no longer want the address to be managed by DHCP. You can use the pntadm -D command or DHCP Manager's Delete Address dialog box.
The following figure shows the Delete Address dialog box.
Figure 10–12 Delete Address Dialog Box
Dialog box shows list of IP addresses to delete and a checkbox labeled Delete from hosts table. Shows OK, Cancel, and Help buttons.
