If you configure a client to use a proxy identity, the client saves its proxyDN and proxyPassword in /var/ldap/ldap_client_cred. For the sake of increased security, this file is restricted to root-access only and the value of proxyPassword is encrypted. While past LDAP implementations have stored proxy credentials in a client's profile, the Solaris 9 LDAP does not. Any proxy credentials set using ldapclient during initialization are stored locally. This results in improved security surrounding a proxy's DN and password information. See Chapter 16, Client Setup (Task) for more information on setting up client profiles.
