The following is a sample audit_control file for the machine dopey. dopey uses two audit file systems on the audit server blinken, and a third audit file system that is mounted from the second audit server winken. The third file system is used only when the audit file systems on blinken become full or unavailable. The minfree value of 20 percent specifies that the warning script is run when the file systems are 80 percent filled and the audit data for the current machine will be stored in the next available audit directory, if any (see the audit_warn(1M) man page). The flags specify that all logins and administrative operations are to be audited (whether or not they succeed), and that failures of all types, except failures to create a file system object, are to be audited.
flags:lo,ad,-all,^-fc naflags:lo,nt minfree:20 dir:/etc/security/audit/blinken/files dir:/etc/security/audit/blinken.1/files # # Audit filesystem used when blinken fills up # dir:/etc/security/audit/winken |
