When you drag a file or folder icon from a regular folder window, the default drag-and-drop behavior is:
A copy operation when you drop the icon onto a diskette window.
A move operation when you drop the icon onto a folder window.
A move operation when you drop the icon onto the Trash Can or to the Trash window.
When you drag a file or folder icon from a diskette window, the default drag-and-drop behavior is:
A copy operation when you drop the icon onto another diskette window.
A copy operation when you drop the icon onto a folder window.
A move operation when you drop the icon onto the Trash Can or to the Trash Can window.
When you drag a file or folder icon from a CD-ROM window, the default drag-and-drop behavior is:
You cannot drag and drop files or folders onto a CD-ROM.
