Solaris Common Desktop Environment: User's Guide
Supported Formats
CDE reads and writes the following file-system formats:
CDE supports DOS High Density and NEC-DOS Medium Density formats whether running on SPARC or IA, but the following restrictions apply to the UNIX format:
Tip –
If you need to use the same diskettes on SPARC-based and IA–based systems, use the DOS High Density format.
