Solaris Common Desktop Environment: User's Guide
Opening a File or Folder
The most basic action you can perform on an object is to open it. “Open” is a very general term, and the action taken depends on the type of object you are opening. For example, opening a folder changes the File Manager view to show the contents of that folder. Opening a data file usually starts the application that created the file and loads the data file.
To Open a File or Folder
