if this option is selected, the external codes for every candidate will appear in each Lookup window after the candidate is entered.
if this option is not selected, the external codes for each candidate will not be displayed after the candidate.
This option can be used to study the input method. For example, to visualize the external code of a Chinese character in that input method.
