The following example uses ChuYin mode to enter Chinese characters representing the statement Taipei's weather is very hot.
Type Control-spacebar to turn on Chinese input mode.
The mode appears in the status area.
Click the Input method selection button on the auxiliary window and select ChuYin input method.
The status area shows that ChuYin input mode is on.
Type w96.
The ChuYin input converter finds several matching characters and displays a lookup choice window:
Press [Shift] + [A] to select the appropriate character.
The radicals are converted and the correct character appears.
