Traditional Chinese Solaris System Administrator's Guide
Using Big5 TTY With EUC Locale
If you are using a Big5 type terminal, you must load the STREAMS module
into the kernel by using the following command as a superuser:
system% su
Password: (Type superuser password here if required.)
# modload /kernel/strmod/big5euc
Type the following command:
- © 2010, Oracle Corporation and/or its affiliates
