System Administration Guide: Resource Management and Network Services
options.ttya.tmpl Template File
The /etc/ppp/options.ttya.tmpl file contains helpful comments about the /etc/ppp/options.tty-name file. The template contains three common options for the /etc/ppp/options.tty-name file.
38400
asyncmap 0xa0000
:192.168.1.1
Option
Definition
38400
Use this baud rate for port ttya.
asyncmap 0xa0000
Assign the asyncmap value of 0xa0000 so that the local machine can communicate with broken peers.
:192.168.1.1
Assign the IP address 192.168.1.1 to all peers that are calling in over the link.
To use /etc/ppp/options.ttya.tmpl at your site, rename /etc/ppp/options.tmpl to /etc/ppp/options.ttya-name. Replace ttya-name with the name of the serial port with the modem. Then modify the file contents as needed by your site.
