System Administration Guide: Resource Management and Network Services
Using /etc/ppp/options.ttyname on a Dial-out Machine
For a dial-out machine, you can create an /etc/ppp/options.ttyname file for the serial port with the modem, or elect not to use /etc/ppp/options.ttyname.
Note -
Solaris PPP 4.0 does not require an /etc/ppp/options.ttyname file to work correctly. If the dial-out machine only has one serial line for PPP and requires few options, you can specify these options in another configuration file or on the command line.
