If you attempt to configure replication over (SSL) with certificate-based authentication, replication does not work if either of the following conditions exist.
The supplier's certificate is self-signed.
The supplier's certificate is only capable of behaving as an SSL server certificate that is unable to "play" the role of the client during an SSL handshake.
Workaround: None.
