Solaris 9 および Solaris 9 9/02 ソフトウェアの韓国語、簡体字中国語、繁体字中国語などアジア言語の一部のパッケージに含まれている preremove スクリプトが、Disk Space Reallocation (DSR) でのアップグレード中に正しく実行されません。Solaris オペレーティング環境の新しいリリースにアップグレードしようとすると、次のエラーメッセージが /var/sadm/system/logs/update_log ファイルに出力されます。
Removing package SUNWkwbcp: /a/var/sadm/pkg/SUNWkwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWkwbcp failed. pkgrm return code = 1 Removing package SUNWkbcp: /a/var/sadm/pkg/SUNWkbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfu Removal of SUNWkbcp failed. pkgrm return code = 1 Removing package SUNWcwbcp: /a/var/sadm/pkg/SUNWcwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWcwbcp failed. pkgrm return code = 1 Removing package SUNWcbcp: /a/var/sadm/pkg/SUNWcbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWcbcp failed. pkgrm return code = 1 Removing package SUNWhwbcp: /a/var/sadm/pkg/SUNWhwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWhwbcp failed. pkgrm return code = 1 Removing package SUNWhbcp: /a/var/sadm/pkg/SUNWhbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWhbcp failed. pkgrm return code = 1 |
回避方法: このエラーメッセージを無視します。
