Mail aliases must be unique within the domain. This section provides the procedures for administering mail alias files. Alternately, you can use the AdminTool's Database Manager application to perform these tasks on the aliases database.
In addition, you can create database files for the local mail host by using makemap. Refer to the makemap(1M) man page. The use of these database files does not provide all of the advantages of using a name service such as NIS or NIS+. However, you should be able to retrieve the data from these local database files faster because no network lookups are involved. For more information, refer to Interactions of sendmail With Name Services and Mail Alias Files in Chapter 23, Mail Services (Reference).
To manage entries in an NIS+ table, you can use the aliasadm command. To list, add, modify, or delete table entries with the aliasadm command, you begin a particular task with the following steps.
Either be a member of the NIS+ group that owns the table, or become root on the mail server, or assume an equivalent role.
For information about roles, refer to “Using Privileged Applications” in System Administration Guide: Security Services.
Complete your task by following the instructions from the example that meets your requirements.
Example—Listing the Entire Contents of the NIS+ mail_aliases Table
Example—Listing an Individual Entry From the NIS+ mail_aliases Table
Example—Listing Partial Matches From the NIS+ mail_aliases Table
Example—Adding Aliases to the NIS+ mail_aliases Table From the Command Line
Example—Adding Entries by Editing an NIS+ mail_aliases Table
In some instances, you should begin the task by compiling a list of each of your mail clients, the locations of their mailboxes, and the names of the mail server systems.
To create a table, follow these instructions.
Initiate an NIS+ table.
# aliasadm -I |
Add entries to the table.
To add two or three aliases, refer to Example—Adding Aliases to the NIS+ mail_aliases Table From the Command Line.
To add more than two or three aliases, refer to Example—Adding Entries by Editing an NIS+ mail_aliases Table.
For more information, refer to the aliasadm(1M) man page.
To see a complete list of the contents of the table, follow these instructions.
List all of the entries in alphabetical order by alias.
# aliasadm -1 |
To see an individual entry from the table, follow these instructions.
List an individual entry.
# aliasadm -m ignatz ignatz: ignatz@saturn # Alias for Iggy Ignatz |
The command matches only the complete alias name, not partial strings. You cannot use metacharacters, such as * and ?, with aliasadm -m.
To see partial matches from the table, follow these instructions.
List partial matches from the table.
# aliasadm -l | grep partial_string |
Use the string of your choice for your search.
To add two or three aliases to the table, follow these instructions.
Compile a list of each of your mail clients, the locations of their mailboxes, and the names of the mail server systems.
(Optional) If necessary, initiate an NIS+ table.
If you are creating a completely new NIS+ mail_aliases table, you must first initiate the table. To complete this task, refer to Example—Initiating an NIS+ mail_aliases Table.
Add aliases to the table.
See this example of a typical entry.
# aliasadm -a iggy iggy.ignatz@saturn "Iggy Ignatz" |
The following list describes the input from the preceding example.
The option for adding an alias
The short form of the alias name
The expanded alias name
The name for the alias in quotation marks
Display the entry that you created and ensure that the entry is correct.
# aliasadm -m alias |
The entry that you created
To add more than two or three aliases to the table, follow these instructions.
Display and edit the aliases table.
# aliasadm -e |
This command displays the table and enables you to edit the table. The editor that you use has been set with the $EDITOR environment variable. If this variable is not set, vi is the default editor.
Use the following format to type each alias on a separate line.
alias: expanded_alias # ["option" # "comments"] |
This column is for the short form of the alias name.
This column is for the expanded alias name.
This column is reserved for future use.
This column is used for comments about the individual alias, such as a name for the alias.
If you leave the option column blank, type an empty pair of quotation marks ("") and add the comments.
The order of the entries is not important to the NIS+ mail_aliases table. The aliasadm -l command sorts the list and displays the entries in alphabetical order.
For more information, refer to Mail Alias Files and the aliasadm(1M) man page.
To edit entries in the table, follow these instructions.
Display the alias entry.
Use the assigned alias name.
Edit the alias entry, as necessary.
# aliasadm -c alias expanded_alias [options comments] |
If necessary, edit the alias name.
If necessary, edit the expanded alias name.
If necessary, edit the option.
If necessary, edit the comment for this entry.
For more information, refer to the aliasadm(1M) man page, as well as Mail Alias Files.
Display the entry that you have edited and ensure that the entry is correct.
To delete entries from the table, follow these instructions.
Delete an entry from the table.
# aliasadm -d alias |
Use the alias name for the entry that you are deleting.
Use the following procedure to facilitate aliasing with an NIS mail.aliases map.
Become root on the NIS master server or assume an equivalent role.
Edit the /etc/mail/aliases file, and make the following entries.
Add an entry for each mail client.
# cat /etc/mail/aliases .. alias:expanded_alias |
Use the short alias name.
Use the expanded alias name (user@host.domain.com).
Ensure that you have a Postmaster: root entry.
# cat /etc/mail/aliases .. Postmaster: root |
Add an alias for root. Use the mail address of the person who is designated as the postmaster.
# cat /etc/mail/aliases .. root: user@host.domain.com |
Use the assigned address of the designated postmaster.
Ensure that the NIS master server is running a name service to resolve the host names on each mail server.
Change to the /var/yp directory.
# cd /var/yp |
Apply the make command.
# make |
The changes in the /etc/hosts and /etc/mail/aliases files are propagated to NIS slave systems. The changes are active in only a few minutes, at most.
Use the following procedure to resolve aliases with a local mail alias file.
Compile a list of each of your users and the locations of their mailboxes.
Become root on the mail server or assume an equivalent role.
Edit the /etc/mail/aliases file and make the following entries.
Add an entry for each user.
user1: user2@host.domain |
Use the new alias name.
Use the actual address for the new alias.
Rebuild the alias database.
# newaliases |
The configuration of the AliasFile option in /etc/mail/sendmail.cf determines whether this command generates in binary form either the single file, /etc/mail/aliases.db, or the pair of files, /etc/mail/aliases.dir and /etc/mail/aliases.pag.
Perform one of the following steps to copy the file or files that were generated.
(Optional) Copy the /etc/mail/aliases, the /etc/mail/aliases.dir, and the/etc/mail/aliases.pag files to each of the other systems.
You can copy the three files by using the rcp or rdist commands. Refer to the rcp(1) man page or the rdist(1) man page for more information. Alternately, you can create a script for this purpose.
When you copy these files, you do not need to run the newaliases command on each of the other systems. However, remember that you must update all the /etc/mail/aliases files each time you add or remove a mail client.
(Optional) Copy the /etc/mail/aliases.db file to each of the other systems.
You can copy the file by using the rcp or rdist commands. Refer to the rcp(1) man page or the rdist(1) man page for more information. Alternately, you can create a script for this purpose.
When you copy this file, you do not need to run the newaliases command on each of the other systems. However, remember that you must update all the /etc/mail/aliases files each time you add or remove a mail client.
To create a keyed map file, follow these instructions.
Become superuser on the mail server or assume an equivalent role.
Create an input file.
Entries can have the following syntax.
old_name@newdomain.com new_name@newdomain.com old_name@olddomain.com error:nouser No such user here @olddomain.com %1@newdomain.com |
Use the user name that was previously assigned with the domain that is newly assigned.
Use the address that is newly assigned.
Use the user name that was previously assigned with the domain that was previously assigned.
Use the domain that was previously assigned.
Use the domain that is newly assigned.
The first entry redirects mail to a new alias. The next entry creates a message when an incorrect alias is used. The last entry redirects all incoming mail from olddomain to newdomain.
Create the database file.
# /usr/sbin/makemap maptype newmap < newmap |
Select a database type, such as dbm, btree, or hash.
Use the name of the input file and the first part of the name of the database file. If the dbm database type is selected, then the database files are created by using a .pag and a .dir suffix. For the other two database types, the file name is followed by .db.
Every system must be able to send mail to a postmaster mailbox. You can create an NIS or NIS+ alias for postmaster, or you can create the alias in each local /etc/mail/aliases file. Refer to these procedures.
How to Create a postmaster Alias in Each Local /etc/mail/aliases File
How to Add the postmaster Mailbox to the Aliases in the /etc/mail/aliases File
If you are creating the postmaster alias in each local /etc/mail/aliases file, follow these instructions.
Become superuser on each local system or assume an equivalent role.
View the /etc/mail/aliases entry.
# cat /etc/mail/aliases # Following alias is required by the mail protocol, RFC 2821 # Set it to the address of a HUMAN who deals with this system's # mail problems. Postmaster: root |
Edit each system's /etc/mail/aliases file.
Change root to the mail address of the person who is designated as the postmaster.
Postmaster: mail_address |
Use the assigned address for the person who is designated as the postmaster.
(Optional) Create a separate mailbox for the postmaster.
You can create a separate mailbox for the postmaster to keep postmaster mail separate from personal mail. If you create a separate mailbox, use the mailbox address instead of the postmaster's personal mail address when you edit the /etc/mail/aliases files. For details, refer to How to Create a Separate Mailbox for postmaster.
If you are creating a separate mailbox for postmaster, follow these instructions.
Create a user account for the person who is designated as postmaster. Put an asterisk (*) in the password field.
For details about adding a user account, refer to “Managing User Accounts and Groups (Tasks)” in System Administration Guide: Basic Administration.
After mail has been delivered, enable the mail program to read and write to the mailbox name.
# mail -f postmaster |
Use the assigned address.
If you are adding a postmaster mailbox to the aliases in the /etc/mail/aliases file, follow these instructions.
Become root on each system or assume an equivalent role.
Use the assigned address of the person who is designated as postmaster.
On the postmaster's local system, create an entry in the /etc/mail/aliases file that defines the name of the alias. sysadmin is an example. Also, include the path to the local mailbox.
# cat /etc/mail/aliases .. sysadmin: /usr/somewhere/somefile |
Create a name for a new alias.
Use the path to the local mailbox.
# newaliases |
