次の例は、/export/home ファイルシステムの復元方法を示します。
# umount /export/home
# newfs /dev/rdsk/c0t0d0s7
newfs: /dev/rdsk/c0t0d0s7 last mounted as /export/home
newfs: construct a new file system /dev/rdsk/c0t0d0s7: (y/n)? y
819314 sectors in 867 cylinders of 15 tracks, 63 sectors
400.1MB in 55 cyl groups (16 c/g, 7.38MB/g, 3584 i/g)
super-block backups (for fsck -F ufs -o b=#) at:
32, 15216, 30400, 45584, 60768, 75952, 91136, 106320, 121504, 136688,
681264, 696448, 711632, 725792, 740976, 756160, 771344, 786528, 801712,
816896,
Verify volume and initialize maps
Media block size is 126
Dump date: Tue Oct 07 08:41:41 2003
Dumped from: the epoch
Level 0 dump of a partial file system on starbug:/export/home/kryten
Label: none
Begin level 0 restore
Initialize symbol table.
Extract directories from tape
Calculate extraction list.
Extract new leaves.
Check pointing the restore
extract file ./export/home/kryten/filea
extract file ./export/home/kryten/fileb
extract file ./export/home/kryten/filec
extract file ./export/home/kryten/letters/letter1
extract file ./export/home/kryten/letters/letter2
extract file ./export/home/kryten/letters/letter3
extract file ./export/home/kryten/reports/reportA
extract file ./export/home/kryten/reports/reportB
extract file ./export/home/kryten/reports/reportC
Add links
Set directory mode, owner, and times.
Check the symbol table.
# mount /dev/dsk/c0t0d0s7 /mnt
# cd /mnt
# ufsrestore rvf /dev/rmt/0
# ls
# rm restoresymtable
# cd /
# umount /mnt
# ufsdump 0ucf /dev/rmt/0 /export/home
# mount /dev/dsk/c0t3d0s7 /export/home
# ls /export/home
