System Administration Guide: Devices and File Systems
SCSI Hot-Plugging With the cfgadm Command (Task Map)
Task
Description
For Instructions
1. Display information about SCSI devices
Display information about SCSI controllers and devices.
How to Display Information About SCSI Devices
2. Unconfigure a SCSI controller
Unconfigure a SCSI controller.
How to Unconfigure a SCSI Controller
3. Configure a SCSI controller
Configure a SCSI controller that was previously unconfigured.
How to Configure a SCSI Controller
4. Configure a SCSI device
Configure a specific SCSI device.
How to Configure a SCSI Device
5. Disconnect a SCSI controller
Disconnect a specific SCSI controller.
How to Disconnect a SCSI Controller
6. Connect a SCSI controller
Connect a specific SCSI controller that was previously disconnected.
SPARC: How to Connect a SCSI Controller
7. Add a SCSI device to a SCSI bus
Add a specific SCSI device to a SCSI bus.
SPARC: How to Add a SCSI Device to a SCSI Bus
8. Replace an identical device on a SCSI controller
Replace a device on the SCSI bus with another device of the same type.
SPARC: How to Replace an Identical Device on a SCSI Controller
9. Remove a SCSI device
Remove a SCSI device from the system.
SPARC: How to Remove a SCSI Device
10. Troubleshooting SCSI configuration problems
Resolve a failed SCSI unconfigure operation.
How to Resolve a Failed SCSI Unconfigure Operation
