This section describes various SCSI hot-plugging procedures that you can perform with the cfgadm command.
These procedures use specific devices as examples to illustrate how to use the cfgadm command to hot-plug SCSI components. The device information that you supply, and that the cfgadm command displays, depends on your system configuration.
The following procedure uses SCSI controllers c0 and c1 and the devices that are attached to them as examples of the type of device configuration information that you can display with the cfgadm command.
If the SCSI device is not supported by the cfgadm command, it does not display in the cfgadm command output.
Become superuser.
Display information about attachment points on the system.
# cfgadm -l Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c1 scsi-bus connected configured unknown |
In this example, c0 and c1 represent two SCSI controllers.
Display information about a system's SCSI controllers and their attached devices.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 scsi-bus connected configured unknown c1::dsk/c1t3d0 disk connected configured unknown c1::dsk/c1t4d0 unavailable connected unconfigured unknown |
The cfgadm -l commands displays information about SCSI HBAs but not SCSI devices. Use the cfgadm -al command to display information about SCSI devices such as disk and tapes.
The following procedure uses SCSI controller c1 as an example of unconfiguring a SCSI controller.
Become superuser.
Unconfigure a SCSI controller.
# cfgadm -c unconfigure c1 |
Verify that the SCSI controller is unconfigured.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 scsi-bus connected unconfigured unknown |
Notice that the Occupant column for c1 specifies unconfigured, indicating that the SCSI bus has no configured occupants.
If the unconfigure operation fails, see How to Resolve a Failed SCSI Unconfigure Operation.
The following procedure uses SCSI controller c1 as an example of configuring a SCSI controller.
Become superuser.
Configure a SCSI controller.
# cfgadm -c configure c1 |
Verify that the SCSI controller is configured.
The previous unconfigure procedure removed all devices on the SCSI bus. Now all the devices are configured back into the system.
The following procedure uses SCSI disk c1t4d0 as an example of configuring a SCSI device.
Become superuser.
Identify the device to be configured.
Configure the SCSI device.
# cfgadm -c configure c1::dsk/c1t4d0 |
Verify that the SCSI device is configured.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 scsi-bus connected configured unknown c1::dsk/c1t3d0 disk connected configured unknown c1::dsk/c1t4d0 disk connected configured unknown |
Disconnecting a SCSI device must be done with caution, particularly when you are dealing with controllers for disks that contain critical file systems such as root (/), usr, var, and the swap partition. The dynamic reconfiguration software cannot detect all cases where a system hang might result. Use this procedure with caution.
The following procedure uses SCSI controller c1 as an example of disconnecting a SCSI device.
Become superuser.
Verify that the device is connected before you disconnect it.
Disconnect the SCSI controller.
# cfgadm -c disconnect c1 WARNING: Disconnecting critical partitions may cause system hang. Continue (yes/no)? y |
This command suspends all I/O activity on the SCSI bus until the cfgadm -c connect command is used. The cfgadm command does some basic checking to prevent critical partitions from being disconnected, but it cannot detect all cases. Inappropriate use of this command can result in a system hang and could require a system reboot.
Verify that the SCSI bus is disconnected.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 unavailable disconnected configured unknown c1::dsk/c1t10d0 unavailable disconnected configured unknown c1::dsk/c1t4d0 unavailable disconnected configured unknown |
The controller and all the devices that are attached to it are disconnected from the system.
The following procedure uses SCSI controller c1 as an example of connecting a SCSI controller.
Become superuser.
Verify that the device is disconnected before you connect it.
Connect the SCSI controller.
# cfgadm -c connect c1 |
Verify that the SCSI controller is connected.
SCSI controller c1 provides an example of how to add a SCSI device to a SCSI bus.
When you add devices, you specify the Ap_Id of the SCSI HBA (controller) to which the device is attached, not the Ap_Id of the device itself.
Become superuser.
Identify the current SCSI configuration.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 scsi-bus connected configured unknown c1::dsk/c1t3d0 disk connected configured unknown |
Add the SCSI device to the SCSI bus.
# cfgadm -x insert_device c1 Adding device to SCSI HBA: /devices/sbus@1f,0/SUNW,fas@1,8800000 This operation will suspend activity on SCSI bus: c1 |
Type y at the Continue (yes/no)? prompt to proceed.
Continue (yes/no)? y SCSI bus quiesced successfully. It is now safe to proceed with hotplug operation. |
I/O activity on the SCSI bus is suspended while the hot-plug operation is in progress.
Connect the device and then power it on.
Type y at the Enter y if operation is complete or n to abort (yes/no)? prompt.
Enter y if operation is complete or n to abort (yes/no)? y |
Verify that the device has been added.
A new disk has been added to controller c1.
The following procedure uses SCSI disk c1t4d0 as an example of replacing an identical device on a SCSI controller.
Become superuser.
Replace a device on the SCSI bus with another device of the same type.
# cfgadm -x replace_device c1::dsk/c1t4d0 Replacing SCSI device: /devices/sbus@1f,0/SUNW,fas@1,8800000/sd@4,0 This operation will suspend activity on SCSI bus: c1 |
Power off the device to be removed and remove it.
Add the replacement device. Then, power it on.
The replacement device should be of the same type and at the same address (target and lun) as the device to be removed
Verify that the device has been replaced.
The following procedure uses SCSI disk c1t4d0 as an example of removing a device on a SCSI controller.
Become superuser.
Remove the SCSI device from the system.
# cfgadm -x remove_device c1::dsk/c1t4d0 Removing SCSI device: /devices/sbus@1f,0/SUNW,fas@1,8800000/sd@4,0 This operation will suspend activity on SCSI bus: c1 |
Verify that the device has been removed from the system.
This section provides error messages and possible solutions for troubleshooting SCSI configuration problems. For more information on troubleshooting SCSI configuration problems, see cfgadm(1M).
cfgadm: Component system is busy, try again: failed to offline:
device path
Resource Information
/dev/dsk/c1t0d0s0 mounted filesystem "/file-system"
You attempted to remove or replace a device with a mounted file system.
Unmount the file system that is listed in the error message and retry the cfgadm operation.
If you use the cfgadm command to remove a system resource, such as a swap device or a dedicated dump device, an error messages similar to the following is displayed if the system resource is still active.
device path
/dev/dsk/device-name swap area
You attempted to remove or replace one or more configured swap areas.
Unconfigure the swap areas on the device that is specified and retry the cfgadm operation.
device path
/dev/dsk/device-name dump device (swap)
You attempted to remove or replace a dump device that is configured on a swap area.
Unconfigure the dump device that is configured on the swap area and retry the cfgadm operation.
device path
/dev/dsk/device-name dump device (dedicated)
You attempted to remove or replace a dedicated dump device.
Unconfigure the dedicate dump device and retry the cfgadm operation.
Use this procedure if one or more target devices are busy and the SCSI unconfigure operation fails. Otherwise, future dynamic reconfiguration operations on this controller and target devices will fail with a dr in progress message.
