Task |
Description |
For Instructions |
1. Display PCI Slot Configuration Information |
Display the status of PCI hot-pluggable devices and slots on the system. | |
2. Remove a PCI adapter card |
Unconfigure the card, disconnect power from the slot, and remove the card from the system. | |
3. Add a PCI adapter card |
Insert the adapter card into a hot-pluggable slot, connect power to the slot, and configure the card. | |
4. Troubleshooting PCI configuration problems |
Identify error message and possible solutions to resolve PCI configuration problems. |
