System Administration Guide: Devices and File Systems
Modifying a CacheFS File System
When you modify a file system in the cache, you need to delete the cache and then re-create it. You might also need to reboot your machine in single-user mode, depending on how your file systems are shared and accessed.
In the following example, the cache is deleted, re-created, and then mounted again with the demandconst option specified for the /docs file system.
# shutdown -g30 -y
Type Cntrl-d to proceed with normal startup,
(or give root password for system maintenance):
# enter password:
Here is where you might be prompted to run fsck on the
file system where the cache is located.
# fsck /local
# mount /local
# cfsadmin -d all /local/mycache
# cfsadmin -c /local/mycache
# init 6
console login:
password:
# mount -F cachefs -o backfstype=nfs,cachedir=/local/cache1,demandconst
merlin:/docs /docs
