Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
PIM Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
PIM Overview
Protocol Description
Configuring PIM
Sample Topology
Default Settings
SEFOS1 Configuration
SEFOS2 Configuration
Enable PIM
Reducing Data Transmission Time Using the SPT
Specify the PIM Threshold That Triggers SPT Switching
Specify the PIM SPT Switch Period
Specify the PIM RP Threshold That Triggers Source-Specific Switching
Specify the PIM RP Switch Period
Monitor the Data Transfer Rate After a Register Stop Message
Configuring PMBR Status
Enable PMBR Status Reporting
Disable PMBR Status Reporting
Enabling Static RP Configurations
Enable Static RP
Disable Static RP
Associate an Interface to a PIM Component
Delete a PIM Interface
Configuring Designated Routers
Prioritize Router Messaging With PIM DR-Priority
Restore the Default Router Priority Designation
Configuring the PIM Override Interval
Specify the Interval to Delay Override Messages
Restore the Default Override Messaging Interval
Configuring PIM LAN Delay
Delay LAN Message Propagation
Restore the Default LAN Delay Interval
Configuring LAN Prune Delay
Enable LAN Prune Delay
Disable LAN Prune Delay
Configuring BSR Candidates
Prioritize BSR Candidates
Restore the Default BSR-Candidate Value
Configuring PIM Query Intervals
Specify the Hello Messaging Interval
Restore the Default Hello Messaging Interval
Configuring PIM Join and Prune Messaging
Specify the Join and Prune Messaging Interval
Restore the Default Message Interval
Managing PIM Components
Create a PIM Component
Delete a PIM Component
Configuring PIM Component Data Routing Modes
Specify a Data Routing Mode
Configuring RP-Candidate Behavior
Specify the Address for the Candidate RP
Delete an RP Candidate
Configuring RP Candidate Hold Time
Specify RP Candidate Hold Time
Restore the Default Candidate RP Hold Time
Configuring Static RPs
Specify the Address for the Static RP
Delete a Static RP
Display RP Details
Enable PIM Neighbor Recognition
Display PIM Multicast Information
To avoid the encapsulation of multicast data packets from the first hop router to the RP, you can send the system a register stop message. You can specify the amount of time (in seconds) the RP monitors the number of register packets after sending a register stop message.
  1. Specify how long the RP will monitor the number of packets received after a register stop message.
    SEFOS# configure terminal
    SEFOS(config)# set ip pim enable
    SEFOS(config)# set ip pim rp-threshold 10
    SEFOS(config)# set ip pim rp-switchperiod 15
    SEFOS(config)# set ip pim regstop-ratelimit-period 10
    SEFOS(config)# end
    This example sets the RP to monitor the number of registered packets received for 10 seconds after a register stop message has been sent.
  2. Ensure that the correct period of time has been set.
    SEFOS# show ip pim thresholds
    PIM SPT Threshold Information
      Group Threshold  : 10
      Source Threshold : 15
      Switching Period : 5
    PIM SPT-RP Threshold Information
      Register Threshold       : 10
      RP Switching Period      : 15
      Register Stop rate limit : 10
