Reducing Data Transmission Time Using the SPT
Specify the PIM Threshold That Triggers SPT Switching
Specify the PIM SPT Switch Period
Specify the PIM RP Threshold That Triggers Source-Specific Switching
Specify the PIM RP Switch Period
Monitor the Data Transfer Rate After a Register Stop Message
Enabling Static RP Configurations
Associate an Interface to a PIM Component
Configuring Designated Routers
Prioritize Router Messaging With PIM DR-Priority
Restore the Default Router Priority Designation
Configuring the PIM Override Interval
Specify the Interval to Delay Override Messages
Restore the Default Override Messaging Interval
Restore the Default LAN Delay Interval
Restore the Default BSR-Candidate Value
Configuring PIM Query Intervals
Specify the Hello Messaging Interval
Restore the Default Hello Messaging Interval
Configuring PIM Join and Prune Messaging
Specify the Join and Prune Messaging Interval
Restore the Default Message Interval
Configuring PIM Component Data Routing Modes
Configuring RP-Candidate Behavior
Specify the Address for the Candidate RP
Configuring RP Candidate Hold Time
Specify RP Candidate Hold Time
Restore the Default Candidate RP Hold Time
You can view the component ID, the multicast group address used by the listed RP, the network address for the source of the multicast routing information, and a summary of the mroute information.
SEFOS# configure terminal SEFOS(config)# set ip pim enable
SEFOS(config)# interface vlan 5
SEFOS(config-if)# ip pim componentId 1
SEFOS(config-if)# ip pim query-interval 60 SEFOS(config-if)# exit SEFOS(config)#
SEFOS(config)# interface vlan 5 SEFOS(config-if)# ip pim bsr-candidate 30 SEFOS(config-if)# exit
SEFOS(config)# ip pim component 1 SEFOS(pim-comp)# rp-candidate holdtime 30 SEFOS(pim-comp)# rp-candidate rp-address 224.1.0.0 255.255.0.0 10.1.0.1 SEFOS(pim-comp)# exit
SEFOS(config)# interface vlan 5 SEFOS(config)# set ip pim static-rp enable SEFOS(config)# ip pim component 1
SEFOS(config)# ip pim component 1 SEFOS(pim-comp)# rp-static rp-address 224.1.0.0 255.255.0.0 10.1.0.1 SEFOS(pim-comp)# exit
SEFOS(config)# set ip igmp enable SEFOS(config)# interface vlan 5 SEFOS(config-if)# set ip igmp enable SEFOS(config-if)# end
Send the IGMP v2 report with a source IP of 10.1.0.10.
SEFOS# show ip pim mroute
IP Multicast Routing Table
Route Flags S: SPT Bit W: Wild Card Bit R: RPT Bit
Timers: Uptime/Expires
Interface State: Interface, State/Mode
PIM Multicast Routing Table For Component 1
(*, 224.1.0.0) ,00:03:53/--- ,RP : 10.1.0.1
Incoming Interface : Vlan5 ,RPF nbr : NULL ,Route Flags : WR
Outgoing InterfaceList :
Vlan5, Forwarding/Sparse ,00:03:53/---Alternatively, you can view the mroute table for specific component.
SEFOS# show ip pim mroute 1 summary
Vlan5, Forwarding/Sparse ,00:03:53/---Or, you can also view the mroute table for a specific group.
SEFOS# show ip pim mroute 224.1.0.0 summary IP Multicast Routing Table -------------------------- Route Flags S: SPT Bit W: Wild Card Bit R: RPT Bit Timers: Uptime/Expires PIM Multicast Routing Table For Component 1 (*, 224.1.0.0) ,00:11:44/--- ,RP : 10.1.0.1 ,Route Flags : WR
