| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System PIMv6 Administration Guide |
Configuring the Topology Example
Enable IPv6 Support and Assign IPv6 Addresses
Configure the Group and Source Thresholds
Configure the SPT Switching Period
Configure the Rendezvous Point Threshold
Configure the RP Switch Period
Configure the regstop Rate Limit
Configuring PIMv6 on an Interface
Associate the PIMv6 Component to an Interface
Configure the Query-Interval Value
Configure the DR Priority Value
Configure the Override Interval
Configure the Message Interval
Configuring the PIMv6 Component
Set the Mode for the PIMv6 Component
Configure the RP-Candidate Hold Time
Configure the RP-Candidate Address
The PIMv6 component corresponds to each instance of a PIMv6 domain. The component is classified as being in the sparse mode. Dense mode is not supported in the 1.2 release.
SEFOS# configure terminal SEFOS(config-if)# set ipv6 pim enable
SEFOS(config)# ip pim component component_ID SEFOS(pim-comp)# end
SEFOS# show ipv6 pim component 2 PIM Component Information --------------------------- Component-Id: 2 PIM Mode: sparse, PIM Version: 2 Elected BSR: :: Candidate RP Holdtime: 0
