| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System PIMv6 Administration Guide |
Configuring the Topology Example
Enable IPv6 Support and Assign IPv6 Addresses
Configure the Group and Source Thresholds
Configure the SPT Switching Period
Configure the Rendezvous Point Threshold
Configure the RP Switch Period
Configure the regstop Rate Limit
Configuring PIMv6 on an Interface
Associate the PIMv6 Component to an Interface
Configure the Query-Interval Value
Configure the DR Priority Value
Configure the Override Interval
Configure the Message Interval
Configuring the PIMv6 Component
Configure the RP-Candidate Hold Time
Configure the RP-Candidate Address
You can set the PIMv6 mode to sparse, which routes protocols using shared trees. In a shared tree, sources forward multicast datagrams to a directly connected router (the designated router). The designated router encapsulates the datagram, and unicasts it to an assigned RP router, which then forwards the datagram to members of multicast groups. The default mode is sparse. As of the current release, dense mode is not supported.
SEFOS# configure terminal SEFOS(config-if)# set ipv6 pim enable
SEFOS(config)# ip pim component component_ID
SEFOS(pim-comp)# set mode sparse SEFOS(pim-comp)# end
SEFOS# show ipv6 pim component 1 PIM Component Information --------------------------- Component-Id: 1 PIM Mode: sparse, PIM Version: 2 Elected BSR: :: Candidate RP Holdtime: 30
