| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System PVRST+ Administration Guide |
Topology Change and Topology Change Detection
Enable IPv6 Support and Assign IPv6 Addresses
Configure the Spanning-Tree Path Cost
Configure the Spanning Tree Link Type
Configure the Spanning-Tree portfast Setting
Configure Spanning Tree Timers
Display the Spanning Tree Status
Configure the Transmit Hold Count
Configuring Trunk and Access Ports
Configure VLANS and Display the PVRST+ Information for VLANs
The RSTP used in the PVRST+ module is based on the IEEE 802.1w rapid reconfiguration. The existing STP takes significant time to reconfigure and to restore the service on link failure or restoration. RSTP avoids reconvergence delay by calculating an alternate root port and immediately switching over to the alternate port if the root port becomes unavailable.
This section contains procedures for configuring RSTP in the PVRST+ software. Throughout this chapter the instructions use, Topology Example.
