Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System PVRST+ Administration Guide |
Topology Change and Topology Change Detection
Enable IPv6 Support and Assign IPv6 Addresses
Configure the Spanning-Tree Path Cost
Configure the Spanning Tree Link Type
Configure the Spanning-Tree portfast Setting
Configure Spanning Tree Timers
Display the Spanning Tree Status
Configure the Transmit Hold Count
Configuring Trunk and Access Ports
Configure VLANS and Display the PVRST+ Information for VLANs
To make the PVRST+ module completely operational, you must configure the VLAN module. Before you configure VLAN as described in these sections, see VLAN Module to ensure that the configuration guidelines are satisfied.
The examples in this section use switch B (hostname TOR-1), port 0/1, and VLAN 10 and VLAN 20.
