| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System OSPFv3 Administration Guide |
Configuration and Testing Topologies
IPv6 Example Topology Interface and Host Addresses
Creating the Base Configuration
Access Global Configuration Mode
Access Interface Configuration Mode
Enabling IPv6 Support and Assigning IPv6 Addresses
Configuring IPv6 Static Routes
Creating the Base Configuration for Example Topologies
Configuring OSPFv3 Interface Parameters
Restore the Default Interface Priority
Configure the Retransmission Interval
Restore the Default Retransmission Value
Restore the Default Transmission Delay
Restore the Default Hello Interval
Restore the Default Dead Interval
Restore the Default OSPF Network Type
Restore the Default Interface Cost
Remove the Demand Circuit Setting
Enable Neighbor Probing on a Demand Circuit
Remove Neighbor Probing on a Demand Circuit
Configuring Neighbor Probe Values
Configure the Neighbor Probe Retransmission Limit
Restore the Default Neighbor Probe Retransmission Limit
Configure the Neighbor Probe Interval
Restore the Default Neighbor Probe Interval
Configuring a Passive Interface
Configure All Interfaces To Be Passive
Configure Specified Interfaces To Be Passive
Restore the Default Routing Updates
Configuring Route Redistribution
Configure Route Redistribution
Configuring Attributes for Redistributed Routes
Configure Redistributed Route Attributes
Delete Redistributed Route Attributes
Configuring the Redistribution of Routes
Restore the Default Redistribution Configuration
Configuring Area Route Summarization
Configure Address Range Aggregation
Configure an Internal Address Range
Disable an Internal Address Range
Convert a Stub Area to a Normal Area
Configure a Default Summary Route for a Stub Area
Configure the Default Summary Route Cost for a Stub Area
Configure the Stability Interval for NSSA
Restore the Default Stability Interval
Configure an NSSA Translation Role
Restore the Default Translation Role
Configure Default Summary Route for an NSSA
Configure the Metric Type for an NSSA
Configuring the Capability in an NSSA Internal Border Router
Configure NSSA Type-7/-5 Conversion
Configure Virtual Link and Route Summarization
Configuring External Database Limit
Configure the External Database Limit
Restore the Default External Database Limit
Configuring the Overflow Exit Interval
Configure the Overflow Exit Interval
Configuring a Demand Extension
See Creating the Base Configuration for Example Topologies for prerequisite configurations for SEFOS4, SEFOS5, and SEFOS7. See IPv6 Example Topology Interface and Host Addresses for the sample configuration of the stub, ASBR, and route redistribution areas.
This example shows how to configure SEFOS4 as an ASBR router for redistributing the external routes into the OSPF domain. This example also shows how to configure area 0.0.0.4 of SEFOS5 as a stub area, and how to configure area 0.0.0.4 of SEFOS7 as a stub area with external routes that are not redistributed into the stub area.
SEFOS# configure terminal SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.4 SEFOS(config-router)# asbr router SEFOS(config-router)# redistribute static SEFOS(config-router)# exit SEFOS(config)# ipv6 route 3333:: 96 fec0::4444:0:2 SEFOS(config)# exit
SEFOS# configure terminal SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.5 SEFOS(config-router)# area 0.0.0.4 stub SEFOS(config-router)# exit
SEFOS# configure terminal SEFOS(config)# ipv6 router ospf SEFOS(config-router)# router-id 10.0.0.7 SEFOS(config-router)# area 0.0.0.4 stub SEFOS(config-router)# exit
SEFOS# show ipv6 ospf route **************************************************** Dest/Prefix-Length NextHop/IfIndex Cost Rt.Type Area fec0::3003:0:0/96 fe80::207:2ff:fe03:401/vlan4 2 interArea 0.0.0.0 fec0::4444:0:0/96 :: /vlan4 1 intraArea 0.0.0.0 SEFOS# show ipv6 ospf database as-external detail Age: 0 Seconds LS Type: External Lsa Link State Id: 0.0.0.2 Adv Rtr Id: 10.0.0.4 Sequence: 0x80000001 Checksum: 0x0bc4 Length: 56 Metric Type: Ext Type2 Metric: 0xa Prefix Length: 96 Prefix Options: 0x00 Referenced LS Type: 0 Address Prefix: 3333:: Fw Address Prefix: 3333::fec0:0 External Route Tag: 0
SEFOS# show ipv6 ospf route OSPFV3 Process Routing Table Dest/Prefix-Length NextHop/IfIndex Cost Rt.Type Area 3333::/96 fec0::4444:0:2/vlan4 10 type2Ext 0.0.0.0SEFOS# show ipv6 ospf database as-external detail fec0::3003:0:0/96 ::/vlan5 1 intraArea 0.0.0.4 fec0::4444:0:0/96 ::/vlan4 1 intraArea 0.0.0.3Age: 63 Seconds LS Type: External LsaLink State Id: 0.0.0.2 Adv Rtr Id: 10.0.0.4Sequence: 0x80000001 Checksum: 0x0bc4 Length: 56Metric Type: Ext Type2 Metric: 0xaPrefix Length: 96 Prefix Options: 0x00Referenced LS Type: 0Addres Prefix: 3333::Fw Addres Prefix: 3333::fec0:0External Route Tag: 0
