| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System OSPFv3 Administration Guide |
Configuration and Testing Topologies
IPv6 Example Topology Interface and Host Addresses
Creating the Base Configuration
Access Global Configuration Mode
Access Interface Configuration Mode
Enabling IPv6 Support and Assigning IPv6 Addresses
Configuring IPv6 Static Routes
Creating the Base Configuration for Example Topologies
Configuring OSPFv3 Interface Parameters
Restore the Default Interface Priority
Configure the Retransmission Interval
Restore the Default Retransmission Value
Restore the Default Transmission Delay
Restore the Default Hello Interval
Restore the Default Dead Interval
Restore the Default OSPF Network Type
Restore the Default Interface Cost
Remove the Demand Circuit Setting
Enable Neighbor Probing on a Demand Circuit
Remove Neighbor Probing on a Demand Circuit
Configuring Neighbor Probe Values
Configure the Neighbor Probe Retransmission Limit
Restore the Default Neighbor Probe Retransmission Limit
Configure the Neighbor Probe Interval
Restore the Default Neighbor Probe Interval
Configuring a Passive Interface
Configure All Interfaces To Be Passive
Configure Specified Interfaces To Be Passive
Restore the Default Routing Updates
Configuring Route Redistribution
Configure Route Redistribution
Configure the Stub Area, ASBR, and Route Distribution
Configuring Attributes for Redistributed Routes
Configure Redistributed Route Attributes
Delete Redistributed Route Attributes
Configuring the Redistribution of Routes
Restore the Default Redistribution Configuration
Configuring Area Route Summarization
Configure Address Range Aggregation
Configure an Internal Address Range
Convert a Stub Area to a Normal Area
Configure a Default Summary Route for a Stub Area
Configure the Default Summary Route Cost for a Stub Area
Configure the Stability Interval for NSSA
Restore the Default Stability Interval
Configure an NSSA Translation Role
Restore the Default Translation Role
Configure Default Summary Route for an NSSA
Configure the Metric Type for an NSSA
Configuring the Capability in an NSSA Internal Border Router
Configure NSSA Type-7/-5 Conversion
Configure Virtual Link and Route Summarization
Configuring External Database Limit
Configure the External Database Limit
Restore the Default External Database Limit
Configuring the Overflow Exit Interval
Configure the Overflow Exit Interval
Configuring a Demand Extension
This example disables an internal range that is not to be advertised.
SEFOS(config-router)# area 0.0.0.6 range fec0::1111:0:0 96 not-advertise summary
SEFOS# show ipv6 ospf area 0.0.0.0 database detail Age: 0 Seconds LS Type: Link Lsa Link State Id: 0.0.0.34 Adv Rtr Id: 10.0.0.1 Sequence: 0x80000003 Checksum: 0xb6f4 Length: 60 Router Priority: 1 Options: 0x33 Prefix: fe80::201:2ff:fe03:401 #Prefixes: 1 Prefix Length (Bytes): 12 Prefix Options: 0x00 Prefix: fec0::2856:0:0 Age: 3 Seconds LS Type: Link Lsa Link State Id: 0.0.0.34 Adv Rtr Id: 10.0.0.8 Sequence: 0x80000002 Checksum: 0x9e06 Length: 60 Router Priority: 1 Options: 0x33 Prefix: fe80::202:2ff:fe03:401 #Prefixes: 1 Prefix Length (Bytes): 12 Prefix Options: 0x00 Prefix: fec0::2856:0:0 Age: 0 Seconds LS Type: Router Lsa Link State Id: 0.0.0.0 Adv Rtr Id: 10.0.0.1 Sequence: 0x80000003 Checksum: 0x7921 Length: 40 Router is an Area Border Router Number of Links: 1 Options: 0x33 Link connected to : transit network Metric: 0x1 Interface Id: 34 Nbr Interface Id: 34 Nbr Router Id: 10.0.0.8 Age: 3 Seconds LS Type: Router Lsa Link State Id: 0.0.0.0 Adv Rtr Id: 10.0.0.8 Sequence: 0x80000003 Checksum: 0x5240 Length: 40 Router is an AS Boundary Router Number of Links: 1 Options: 0x33 Link connected to : transit network Metric: 0x1 Interface Id: 34 Nbr Interface Id: 34 Nbr Router Id: 10.0.0.8 Age: 3 Seconds LS Type: Network Lsa Link State Id: 0.0.0.34 Adv Rtr Id: 10.0.0.8 Sequence: 0x80000002 Checksum: 0x2294 Length: 32 Options: 0x33 Attached Router: 10.0.0.8 Attached Router: 10.0.0.1 Age: 3 Seconds LS Type: Intra Area Prefix Lsa Link State Id: 0.0.0.0 Adv Rtr Id: 10.0.0.8 Sequence: 0x80000006 Checksum: 0x18ff Length: 48 #Prefixes: 1 Referenced LS Type: Network Lsa Ref Link State Id: 0.0.0.34 Ref Adv Router: 10.0.0.8 Prefix Length (Bytes): 12 Prefix Options: 0x00 Metric: 0x0 Prefix: fec0::2856:0:0
