| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 6 Gb SAS REM HBA Installation Guide For HBA Models SGX-SAS6-REM-Z and SG-SAS6-REM-Z |
Valid Drive Mix Configurations With HDDs and SSDs
Operating System and Technology Requirements
Chapter 2 Hardware Installation and Removal
Chapter 3 Creating a Bootable Drive in a Preboot Environment
The Sun Storage 6 Gb SAS REM HBA (SGX-SAS6-REM-Z, SG-SAS6-REM-Z) provides eight serial PHYs for connection to SAS/SATA (Serial ATA) devices. Each PHY is capable of 1.5 Gb, 3 Gb, or 6 Gb SAS and SATA link rates. The PCIe transmission and reception data rate is 5 Gb in each direction, yielding a total bandwidth of 10 Gb for each full-duplex lane.
The HBA contains on-board Flash ROM for storing BIOS and firmware, and NVSRAM for embedded mirroring. The LEDs on the HBA report a heartbeat, activity, and fault conditions when detected by the firmware. Fusion-MPT firmware operates the HBA.
The functionality of the HBA comes from the LSISAS2008 controller chip. The HBA controller connects up to eight SAS/SATA devices to a computer system through the PCIe signals routed through the mezzanine connector. The HBA controller uses eight PCIe PHYs.
The HBA has the following features:
Serial SCSI protocol (SSP), serial ATA tunneling protocol (STP), and serial management protocol (SMP), as defined, in the Serial Attached SCSI (SAS) Specification, version 2.0
Support for RAID levels 0, 1, and 10
Support for a maximum of two logical RAID volumes that can be provided by the HBA
Support for a maximum of 10 physical devices within any single RAID volume and a maximum of fourteen physical devices within all RAID volumes combined
Configurable drive spin-up sequencing on a per-PHY basis
A serial, point-to-point, enterprise-level storage interface
Ability to transfer data using SCSI information units
Compatibility with SATA target devices
Narrow and wide ports (see 6 Gb SAS Bandwidths)
Oracle's Sun Storage 6 Gb SAS REM HBA shows the physical features of the HBA.
Figure 1-1 Oracle's Sun Storage 6 Gb SAS REM HBA
