| Skip Navigation Links | |
| Exit Print View | |
Sun Storage 2500-M2 Arrays Hardware Release Notes, Release 6.10 |
Supported Disk Drives and Tray Capacity
Array Expansion Module Support
Supported Host Bus Adaptors (HBAs)
Supported FC and Multilayer Switches
ALUA/TPGS Multipathing with VMware
Procedure for ESX4.1U2 and ESXi5.0
Procedure for ESX4.1U3 and ESXi5.0U1
SAS Host Ports on the Sun Storage 2540-M2
Log Events With smartd Monitoring Enabled
Kernel Panics During Controller Firmware (CFW) Download
Kernel Panics During Controller Firmware Download
Network Interface on Device eth0 Fails to Come Online When Booting a Host
Tasks Aborts Are Logged During a Controller Firmware Upgrade
Unable to Add More Than 117 Volumes to the Oracle Virtual Machine (OVM) Manager Database
After an NVSRAM Download, a Controller Reboots a Second Time when the NVSRAM is Activated
Input/Output (I/O) Errors Occur when Disconnection of Devices from a SAS Switch Is Not Detected
Host Operating System Logs "Hung Task" During a Path Failure
Data is Misread when a Physical Drive Has an Unreadable Sector
This document contains important release information about Oracle's Sun Storage 2500-M2 arrays managed by Sun Storage Common Array Manager (CAM), Version 6.10. Read this document so that you are aware of issues or requirements that can affect the installation and operation of the array.
The release notes consist of the following sections:
