| Skip Navigation Links | |
| Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Windows Operating System |
Part I Windows Server Installations
1. Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Windows Server Operating Systems
Windows Installation Prerequisites
Windows Server Installation Task Overview
SAS PCIe HBAs Requiring LSI Mass Storage Driver for Windows Server 2008 SP2
3. Installing Windows Server 2008
Installing Windows Server Using Local or Remote Media
Windows Server Installation Using a PXE Network Boot
4. Post Installation of Windows Server 2008
Installing Critical Device Drivers and Supplemental Software
Installing Supplemental Software
5. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Windows Server System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
Verification of BIOS Factory Defaults
D. Incorporating Device Drivers Into Windows Server 2008 WIM Images for Windows Deployment Services
This chapter describes how to get started installing the Microsoft Windows Server 2008 SP2 and the Microsoft Windows Server 2008 R2 operating systems manually on your server.
Note - The term “manually” refers to performing the installation by following the instructions provided in Chapters 2 through 4 of this guide, and not using the Oracle Hardware Installation Assistant. If you prefer to perform an assisted Windows installation by using Oracle Hardware Installation Assistant, see Chapter 1, Assisted OS Installation With Oracle Hardware Installation Assistant of this guide.
Topics discussed in this chapter include:
