| Skip Navigation Links | |
| Exit Print View | |
Sun Blade 6000 Virtualized 40 GbE Network Express Module Product Notes |
Product Compatibility Information
Supported Software and Firmware
Available Firmware and Software
Hardware and Networking Issues
sxge Device Corresponding to Port 1 Cannot Communicate with External Hosts in 40G or 1G Mode
CMM Minimum Version and CMM ILOM Upgrade Requirement (7046303)
Cannot Unload sxge When Interfaces are Unplumbed (7045733)
Hot Plug is Not Supported by VMware
PCI Correctable Errors Might Occur When Using NEM (7012350 and 7064505)
Hot Plug is Not Supported by Windows 2008 R2 with Sun Blade X6270 M2 and NEM (7050066)
Sometimes sxge Ports Fail to Enumerate During Hot-plug with Sun Blade X6270 M2 Blades (7087921)
ILOM Web GUI Reports Error: “Command Failed” (16092938)
Unable to Access NEM by Clicking on Graphic from the CMM ILOM Web GUI (7099903)
The highest lane number in the output of show peu command on NEM CLI is incorrect.
> show peu PEU 0 width=4 speed=5G recv_errors(0-8): 00 00 00 00-00 00 00 00 PEU 1 width=8 speed=5G recv_errors(0-8): 00 00 00 00-00 00 00 00 PEU 2 width=8 speed=5G recv_errors(0-8): 00 00 00 00-00 00 00 00 PEU 3 width=4 speed=5G recv_errors(0-8): 01 01 01 01-01 01 01 01 PEU 4 width=8 speed=5G recv_errors(0-8): 01 01 01 01-01 01 01 01 PEU 5 width=8 speed=5G recv_errors(0-8): 00 00 00 00-00 00 00 00 PEU 6 width=8 speed=5G recv_errors(0-8): 01 01 01 01-01 01 01 01 PEU 7 width=8 speed=5G recv_errors(0-8): 00 00 00 00-00 00 00 00 PEU 8 width=8 speed=5G recv_errors(0-8): 01 01 01 01-01 01 01 01 PEU 9 width=8 speed=5G recv_errors(0-8): 00 00 00 00-00 00 00 00
Read the output recv_errors (0-8) as recv_errors (0-7). Functionality is not affected.
