| Skip Navigation Links | |
| Exit Print View | |
Sun Blade 6000 Virtualized 40 GbE Network Express Module Product Notes |
Product Compatibility Information
Supported Software and Firmware
Available Firmware and Software
Hardware and Networking Issues
sxge Device Corresponding to Port 1 Cannot Communicate with External Hosts in 40G or 1G Mode
CMM Minimum Version and CMM ILOM Upgrade Requirement (7046303)
Cannot Unload sxge When Interfaces are Unplumbed (7045733)
Hot Plug is Not Supported by VMware
PCI Correctable Errors Might Occur When Using NEM (7012350 and 7064505)
Sometimes sxge Ports Fail to Enumerate During Hot-plug with Sun Blade X6270 M2 Blades (7087921)
ILOM Web GUI Reports Error: “Command Failed” (16092938)
Highest Lane Number in show peu Output is Incorrect (7039713)
Unable to Access NEM by Clicking on Graphic from the CMM ILOM Web GUI (7099903)
Upon hot insertion of a NEM, Windows OS fails to recognize the NEM because of the PCIe bridge. (The Sun Blade 6000 Virtualized 40 GbE Network Express Module has a PCIe switch with two downstream ports and one upstream port.)Hot plug insertion of the NEM into a Sun Blade 6000 Chassis (C10 Chassis) will fail on Sun Blade X6270 M2 Server Module running Windows 2008 R2. The NEM will not be detected by the blade.
