| Skip Navigation Links | |
| Exit Print View | |
SPARC SuperCluster T4-4 Zones With Oracle Database on Database Domains Configuration Guide |
Planning to Set Up Zones on Database Domains
Understanding Domain Configurations
Determining the Cores Available for Domains and Zones
Zones and Cluster Planning for Database Domains
Guidelines for Planning the Number of Zones and Clusters
Guidelines for Planning the Storage Server Disk Group Layout
Planning the Exadata Storage Server Disk Group Layout
Understanding an Example Scenario
Recording Your Existing and Planned Configuration Information
Recording Your Existing Configuration
Recording Your Zone Configuration Information
Recording Your Cluster Configuration Information
Recording Your Exadata Storage Server Disk Group Layout
Understanding Network Considerations
Understanding the Networking Setup Before Zone Creation
Host Management Network Before Zone Creation
Client Access Network Before Zone Creation
Understanding the Networking Setup After Zone Creation
Host Management Network After Zone Creation
Client Access Network After Zone Creation
InfiniBand Network After Zone Creation
Understanding the Network Setup for Clusters
Preparing to Configure Zones on Database Domains
Determine the Repository Location
Install or Update Packages From the Remote Repository
Install or Update Files From the Local Repository
Verify Configuration Tool Installation
Creating Configuration Files Using OEDA
Verify Exadata Storage Server Disk Space for Additional Zones
Creating Configuration Files Using OEDA: Manual Procedures
Oracle Exadata Deployment Assistant Overview
Complete the Customer Details Page
Complete the Hardware Selection Page
Complete the Define Customer Networks Page
Complete the Administration Network Page
Complete the Client Ethernet Network Page
Complete the Identify Compute Node OS and Enable Capacity-on-Demand Configuration Page
Review the Information in the Management and Private Networks Page
Complete the Define Clusters Page
Set Zone Default Configurations
Complete the Cluster Review and Edit SCAN, Client, VIP and Optional Backup Networks Page
Verify Remaining Configuration Information
Generate the Configuration Files
Creating Configuration Files Using OEDA: Automated Procedures
Locate the Necessary Files to Set Up Zones
Import the Most Recent OEDA Configuration File
Review Existing Configuration Information
Review the Information in the Identify Compute Node Operating System Page
Creating the Template Zone on Each Database Domain
Create a Template Zone on a Database Domain
Delete a Template Zone From a Database Domain
Determining if Additional VNETs Are Needed for a Database Domain
Determine if Additional VNETs Are Needed (CPU-to-Database Domain Mapping)
Determine if Additional VNETs Are Needed (Software Commands)
Set Up Public Key Authentication for ZFS Storage Controllers
Creating Additional Links on the IB Storage Network for Zones
Create Additional Links on the IB Storage Network for Zones
Connection to the InfiniBand network is achieved through the InfiniBand host channel adapters (HCAs) installed in express module slots in each SPARC T4-4 server. There are four InfiniBand HCAs in each SPARC T4-4 server.
The InfiniBand HCAs, and the ports on each HCA, that are assigned to each domain will vary, depending on the number and type of domains on each SPARC T4-4 server:
One total domain – The HCAs and the ports on those HCAs that are used to connect to the InfiniBand network will vary, depending on the type of domain:
Application Domain: The InfiniBand HCA installed in express module slot 1, and ports 1 and 2 on that InfiniBand HCA, are used for connection to the InfiniBand network.
Database Domain: The following InfiniBand HCAs and ports are used for connection to the InfiniBand network:
- Express module slot 1, ports 1 and 2
- Express module slot 9, ports 1 and 2
- Express module slot 7, ports 1 and 2
- Express module slot 12, ports 1 and 2
Two total domains – The HCAs and the ports on those HCAs that are used to connect to the InfiniBand network will vary, depending on the type of domain:
Application Domains:
- Application Domain as the first domain:
-- Express module slot 1, port 1
-- Express module slot 9, port 2
- Application Domain as the second domain:
-- Express module slot 7, port 1
-- Express module slot 12, port 2
Database Domains:
- Database Domain as the first domain:
-- Express module slot 1, ports 1 and 2
-- Express module slot 9, ports 1 and 2
- Database Domain as the second domain:
-- Express module slot 7, ports 1 and 2
-- Express module slot 12, ports 1 and 2
Three total domains – The HCAs and the ports on those HCAs that are used to connect to the InfiniBand network will vary, depending on the type of domain:
- Application Domain as the second domain: Express module slot 7, ports 1 and 2
- Application Domain as the third domain: Express module slot 12, ports 1 and 2
Database Domains:
- Database Domain as the second domain: Express module slot 7, ports 1 and 2
- Database Domain as the third domain: Express module slot 12, ports 1 and 2
Four total domains – The HCAs and the ports on those HCAs that are used to connect to the InfiniBand network are the same, regardless of the type of domain:
First domain: Express module slot 2, ports 1 and 2
Second domain: Express module slot 10, ports 1 and 2
Third domain: Express module slot 6, ports 1 and 2
Fourth domain: Express module slot 14, ports 1 and 2
