Supported Versions of Oracle Solaris OS, Firmware, and Software
Determining Oracle Solaris 11 OS Package Update Version
Determining Oracle Solaris 10 Patch Revision
Minimum Required Patchset for Oracle Solaris 10 8/11 OS
Minimum Required Patchsets and SPARC Bundle for Oracle Solaris 10 9/10 OS
Minimum Required Patchsets and SPARC Bundle for Oracle Solaris 10 10/09 OS
Support for new 16 Gbyte and 32 Gbyte DIMMs
Rules for I/O Slot Use by Certain Cards
Use Links Labeled SPARC T3 to Download sas2ircu Firmware and Documentation for SPARC T4 Servers
Sun Type 6 Keyboards Are Not Supported By SPARC T4 Series Servers
Caution Needed When Removing a SATA Data Cable From a Backplane Connector
Caution Needed When Handling the Connector Board
Server Panics When Booting From a USB Thumbdrive Attached to the Front USB Ports (Bug ID 15667682)
PCIe Correctable Errors Might Be Reported (Bug ID 15720000, Bug ID 15722832)
Upon a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (Bug ID 15733431)
reset /SYS Operations Can Cause the SAS Controller to Disappear (Bug ID 15737475)
Rebooting an SDIO-SAS HBA Guest Domain Might Generate ereport.io.pciex.pl.re (Bug ID 15718101)
Characters Are Occasionally Dropped at the Oracle OpenBoot Prompt (Bug ID15813690)
Cannot Boot Oracle Solaris 10 10/09 OS (U8) From the Internal DVD
Spurious Interrupt Message in System Console (Bug ID 15651697, Bug ID 15771956, Bug ID 15771958)
Spurious Error Message During Initial Oracle Solaris 10 OS Installation (Bug ID 15658412)
Memory Allocation Issues With Emulex 8Gb HBAs In a Magma IO Expansion Box (Bug ID 15666779)
Fault Management Sometimes Sends Resolved Cases to the SP (Bug ID 15667874, Bug ID 15741999)
The trapstat -T Command Causes Bad Watchdog Resets at TL2 (Bug ID 15720390)
ereport.fm.fmd.module Generated During a Reboot of an SDIO Domain (Bug ID 15738845, Bug ID 15742069)
Benign Error Message: mptsas request inquiry page 0x83 for target:a, lun:0 failed! (Bug ID 15809005)
Some pciex8086,105f Devices Fail to Attach (Bug ID 15774699)
L2 Cache Uncorrectable Errors Causing a Reboot Abort (Bug ID 15826320)
Cold Reset Adds One Day to System Time (CR 15764743, Bug ID 15765255, Bug ID 15765770)
Timestamp for an Oracle ILOM Fault/Critical Event Might Be Off by One Hour (Bug ID 15802097)
Units Used to Define the MIB Power Management Time Limit Are Reported in Seconds (Bug ID 15675720)
Explicit Processor Binding Might Block Strand Retirement (Bug ID 15733312)
Blue OK-to-Remove LED On Drive Does Not Light When The Drive Is Ready To Remove (Bug ID 15737491)
System Firmware 8.2.0 Contains a New Version of the scvar Database (Bug ID 16184046)
System Firmware 8.3.0.b Incompatible with the Sun Flash Accelerator F40 PCIe Card (Bug ID 16813726)
To install Oracle Solaris 11 without using an IPS AutoInstall server on the network, you can use Oracle Solaris media in a DVD drive, either built into the server or attached to a USB port. You also can boot from an ISO image copied to a DVD disk, hard disk, or SSD.
Starting with Oracle Solaris 11.2 and System Firmware 8.5.1.x, you can install the OS on this server from an image copied to a USB flash drive. That USB image is available for download at the same location as the ISO images:
http://www.oracle.com/technetwork/serverstorage/solaris11/downloads/index.html
You also can create a persistent device alias for a device connected to a USB port.
For more information see “Installing Oracle Solaris 11.2 Systems” at:
http://docs.oracle.com/cd/E36784_01
You can boot Oracle Solaris 11 from drives installed in the server (hard disk, SDD, or DVD) or from devices connected to a USB port.
For the path to identify a USB port in a boot command, refer to this table:
