| Skip Navigation Links | |
| Exit Print View | |
man pages section 3: Extended Library Functions, Volume 1 Oracle Solaris 11 Information Library |
CIRCLEQ_HEAD_INITIALIZER(3EXT)
cpc_walk_generic_events_all(3CPC)
cpc_walk_generic_events_pic(3CPC)
ct_dev_status_get_aset(3CONTRACT)
ct_dev_status_get_dev_state(3CONTRACT)
ct_dev_status_get_minor(3CONTRACT)
ct_dev_status_get_noneg(3CONTRACT)
ct_dev_tmpl_clear_noneg(3CONTRACT)
ct_dev_tmpl_get_aset(3CONTRACT)
ct_dev_tmpl_get_minor(3CONTRACT)
ct_dev_tmpl_get_noneg(3CONTRACT)
ct_dev_tmpl_set_aset(3CONTRACT)
ct_dev_tmpl_set_minor(3CONTRACT)
ct_dev_tmpl_set_noneg(3CONTRACT)
ct_event_read_critical(3CONTRACT)
ct_pr_event_get_exitstatus(3CONTRACT)
ct_pr_event_get_gcorefile(3CONTRACT)
ct_pr_event_get_pcorefile(3CONTRACT)
ct_pr_event_get_pid(3CONTRACT)
ct_pr_event_get_ppid(3CONTRACT)
ct_pr_event_get_sender(3CONTRACT)
ct_pr_event_get_senderct(3CONTRACT)
ct_pr_event_get_signal(3CONTRACT)
ct_pr_event_get_zcorefile(3CONTRACT)
ct_pr_status_get_contracts(3CONTRACT)
ct_pr_status_get_fatal(3CONTRACT)
ct_pr_status_get_members(3CONTRACT)
ct_pr_status_get_param(3CONTRACT)
ct_pr_status_get_svc_aux(3CONTRACT)
ct_pr_status_get_svc_creator(3CONTRACT)
ct_pr_status_get_svc_ctid(3CONTRACT)
ct_pr_status_get_svc_fmri(3CONTRACT)
ct_pr_tmpl_get_fatal(3CONTRACT)
ct_pr_tmpl_get_param(3CONTRACT)
ct_pr_tmpl_get_svc_aux(3CONTRACT)
ct_pr_tmpl_get_svc_fmri(3CONTRACT)
ct_pr_tmpl_get_transfer(3CONTRACT)
ct_pr_tmpl_set_fatal(3CONTRACT)
ct_pr_tmpl_set_param(3CONTRACT)
ct_pr_tmpl_set_svc_aux(3CONTRACT)
ct_pr_tmpl_set_svc_fmri(3CONTRACT)
ct_pr_tmpl_set_transfer(3CONTRACT)
ct_status_get_cookie(3CONTRACT)
ct_status_get_critical(3CONTRACT)
ct_status_get_holder(3CONTRACT)
ct_status_get_informative(3CONTRACT)
ct_status_get_nevents(3CONTRACT)
ct_status_get_nevid(3CONTRACT)
ct_status_get_ntime(3CONTRACT)
ct_status_get_qtime(3CONTRACT)
ct_status_get_state(3CONTRACT)
ct_status_get_zoneid(3CONTRACT)
ct_tmpl_get_critical(3CONTRACT)
ct_tmpl_get_informative(3CONTRACT)
ct_tmpl_set_critical(3CONTRACT)
ct_tmpl_set_informative(3CONTRACT)
dat_evd_clear_unwaitable(3DAT)
dat_get_consumer_context(3DAT)
dat_registry_add_provider(3DAT)
dat_registry_list_providers(3DAT)
dat_registry_remove_provider(3DAT)
dat_set_consumer_context(3DAT)
devid_deviceid_to_nmlist(3DEVID)
di_link_next_by_lnode(3DEVINFO)
di_link_next_by_node(3DEVINFO)
di_lnode_private_get(3DEVINFO)
di_lnode_private_set(3DEVINFO)
di_minor_private_get(3DEVINFO)
di_minor_private_set(3DEVINFO)
di_path_client_devfs_path(3DEVINFO)
di_path_client_next_path(3DEVINFO)
di_path_phci_next_path(3DEVINFO)
di_path_prop_lookup_bytes(3DEVINFO)
di_path_prop_lookup_int64s(3DEVINFO)
di_path_prop_lookup_ints(3DEVINFO)
di_path_prop_lookup_strings(3DEVINFO)
di_path_prop_strings(3DEVINFO)
di_prom_prop_lookup_bytes(3DEVINFO)
di_prom_prop_lookup_ints(3DEVINFO)
di_prom_prop_lookup_strings(3DEVINFO)
di_prop_lookup_bytes(3DEVINFO)
di_prop_lookup_int64(3DEVINFO)
di_prop_lookup_strings(3DEVINFO)
ea_match_object_catalog(3EXACCT)
- identify file system attributes
cc [ flag… ] file… -lfstyp -lnvpair [ library… ]
#include <libnvpair.h>
#include <libfstyp.h>
int fstyp_ident(fstyp_handle_t handle, const char *fstyp,
const char **ident);Opaque handle returned by fstyp_init(3FSTYP).
Opaque argument that specifies the file system type to be identified.
File system type returned if identification succeeds.
The fstyp_ident() function attempts to identify a file system associated with the handle. If the function succeeds, the file system name is returned in the ident pointer.
If fstype is NULL, the fstyp_ident() function tries all available identification modules. If fstype is other than NULL, fstyp_ident() tries only the module for the file system type which is specified.
The fstyp_ident() function returns 0 on success and an error value on failure. See fstyp_strerror(3FSTYP).
fstyp_init(3FSTYP), fstyp_mod_init(3FSTYP), fstyp_strerror(3FSTYP), libfstyp(3LIB), attributes(5)
