Use this guide as a companion guide to the Oracle Fusion Middleware Developing Mobile Applications with Oracle Mobile Application Framework Guide, which describes how to develop mobile applications using Oracle Mobile Application Framework (MAF). Oracle MAF is the framework used to create mobile enterprise applications for JD Edwards EnterpriseOne. You can access the Oracle MAF guide here:
http://docs.oracle.com/middleware/maf210/mobile/develop-maf/toc.htm
The JD Edwards EnterpriseOne Tools Developing and Customizing Mobile Enterprise Applications Guide includes:
An overview of the environment required for developing EnterpriseOne mobile enterprise applications, which includes Oracle MAF and JD Edwards EnterpriseOne-specific extensions and tools, referred to as JDE Mobile Helpers.
See Chapter 2, "Introduction to Mobile Enterprise Application Development" for more information.
How to use the JDE Mobile Helpers with Oracle MAF to create custom EnterpriseOne mobile enterprise applications.
See the following chapters for more information:
Step-by-step instructions on how to create a sample application, including how to add features with JDE Mobile Helpers.
How to use EnterpriseOne mobile application archives (MAAs) to generate mobile application binaries for internal distribution.
This guide also references JD Edwards EnterpriseOne Mobile Framework Java APIs for developing custom mobile enterprise applications. Descriptions of these APIs can be found in a Javadoc entitled JD Edwards EnterpriseOne Mobile Framework Java API Reference.
