Use this guide as a companion guide to the Fusion Middleware Fusion Developer's Guide for Oracle Application Development Framework, which describes how to develop web applications using Oracle Application Development Framework (ADF). Oracle ADF is the framework used to create web applications for JD Edwards EnterpriseOne. You can access the Oracle ADF documentation here:
http://docs.oracle.com/middleware/1213/adf/docs.htm
The JD Edwards EnterpriseOne Tools Developing and Customizing EnterpriseOne Simplified User Applications Guide includes:
An overview of the environment required for developing EnterpriseOne ADF enterprise applications, which includes Oracle ADF and JD Edwards EnterpriseOne-specific extensions and tools, referred to as JDE ADF Helpers.
See Chapter 2, "Introduction to Simplified Application Framework Development"for more information.
How to use the JDE ADF Helpers with Oracle ADF to create custom EnterpriseOne ADF applications.
See the following chapters for more information:
Step-by-step instructions on how to create a sample application, including how to add features with JDE ADF Helpers.
