This appendix discusses creating database schemas with Repository Creation Utility (RCU) 11.1.1.5. Prior running this utility, you must have a functioning database such as Oracle database 11g. RCU is a 32-bit application and is available on only Windows x86 and Linux x86 platforms, but you can create schemas on other supported platforms.
The previous version of RCU, such as 11.1.1.2, is not compatible with OFMW 11.1.1.5. You must use 11.1.1.5.
You must have a database installed and configured.
If your existing database is not UTF-8 format, you will get a warning message that you can ignore.
You must alter these Oracle database parameters:
Alter system set processes=500 scope=spfile
Alter system set open_cursors=800 scope=spfile
Restart database before running RCU
Use these steps to launch the Repository Creation Utility.
Download and unzip the ofm_rcu_win_11.1.1.5.0_disk1_1of1.zip file.
Run rcu.bat on Windows and rcu on UNIX.
Click Next on the Welcome page.
Select the Create option.
Enter the database connection information.
The utility performs a prerequisites check.
On Select Components, enter the prefix that identifies your environment in the Create a new Prefix field.
In the Component area, select the schemas you need to create.
For WebCenter - select the WebCenter Suite
For OAM/OID - select Identity management
For SOA - select SOA and BPM Infrastructure
You can rerun this utility anytime to add more database schemas.
The utility performs the prerequisites again.
Enter the schema passwords.
Enable the Activity Graph and Analytics option.
Review the tablespace mapping.
This example shows a different schema prefix than the default, which is DEV.
The utility creates any tablespaces that do not already exist.
The utility validates and creates the tablespaces.
Review the summary.
Click Create to start the tablespaces creation.
Click Close to exit Repository Creation Utility.
Verify the schemas creation from Oracle Database console.
