Selecting and Configuring Character Sets and Language Input and Output
This chapter provides overviews of character sets and selecting character sets and discusses how to:
Click to jump to parent topicUnderstanding Character Sets
This section discusses:
Click to jump to top of pageClick to jump to parent topicCharacter Sets
Before you install your PeopleSoft system you must select an appropriate character set for PeopleSoft client workstations, application servers, and database servers.
A character set, also known as a code page, is an ordered set of characters in which each character is mapped to a numeric index, called a codepoint. This codepoint stores character data in a computer system. Many hundreds of character sets exist. Some are international standards, maintained by the International Organization for Standardization (ISO), some are country-specific standards, and others are specific to a particular computer system vendor. Given the number of separate computers that are involved in a typical PeopleSoft installation, it is likely that your system uses several different character sets.
Click to jump to top of pageClick to jump to parent topicCommon Character Sets
Although there is general agreement on the content and arrangement of most character sets, especially those that are maintained by the ISO, many different names are used by vendors and software packages for similar or identical character sets. US-ASCII encodes the basic characters and symbols that are needed to write the English language. However, US-ASCII is limited to 127 characters and cannot represent many characters that are needed by Western European languages, such as French and German, let alone ideographic languages, such as Japanese and Chinese, in which each character represents a word or concept. Many character sets, however, include all US-ASCII characters in addition to their other characters.
The following table illustrates just a few common character sets that you are likely to encounter and some of the names that are used by different vendors to refer to them:
Character Set
Description and Comments
Type
PeopleSoft and SQR Name
Oracle DBMS Name
Microsoft Windows Name
ISO 8859-1
Western European Latin-1. Contains characters that are required to represent Western European languages. However, does not include the euro symbol, the trademark (TM) symbol, or the oe ligature.
ISO
LATIN1 or ISO_8859-1
WE8ISO8859P1
CP28591
Microsoft Code Page 1252
Microsoft Code Page 1252 - Western European. Very similar to ISO 8859-1, except for the inclusion of additional characters. Includes the euro symbol, trademark (TM) symbol, and oe ligature, but using a different codepoint than ISO 8859-15.
Vendor (Microsoft)
CP1252
WE8MSWIN1252
CP1252
ISO 8859-2
Central/Eastern European Latin-2. Contains characters that are required for Central European languages, including Czech, Hungarian, and Polish. Does not include the euro symbol.
ISO
LATIN2 or ISO_8859-2
EE8ISO8859P2
CP28592
ISO 8859-15
Western European extended Latin-9. Similar to ISO 8859-1, but contains the euro symbol, oe ligature, and several characters that are required for Icelandic.
ISO
LATIN9 or ISO_8859-15
WE8ISO8859P15
CP28605
Shift-JIS
Most common Japanese character set. Defines thousands of characters for writing Japanese.
Country (Japan)
SJIS
JA16SJIS or JA16SJISTILDE
CP932
IBM CCSID 37
IBM Coded Character Set ID 37. Western European Multilingual EBCDIC-based character set.
Vendor (IBM)
EBCDIC
WE8EBCDIC37
CP1140
GB18030
Chinese national character set
Country (China)
GB18030
GB18030
GB18030
Some of these character sets, such as ISO 8859-1 and IBM CCSID 37, require only one byte to represent each character. For example, in ISO 8859-1, the hexadecimal number 61 represents the lowercase Latin letter a. However, larger character sets, such as Shift-JIS, may require more than one byte to represent each character.
Click to jump to top of pageClick to jump to parent topicThe Unicode Standard
The most important consideration when dealing with character sets across a system is ensuring that all characters that you plan to represent within the PeopleSoft system exist in the character set that is used by each component of the system.
For example, if you plan to maintain Japanese characters in employee names, you must ensure that:
For example, the Japanese Shift-JIS character set contains Japanese and many US-ASCII characters; it is sufficient for encoding both English data and the primary characters that are required in Japanese. However, it does not include the accented Latin characters that are needed for French, German, and other languages, so it is not a suitable character set for implementations that encompass Western European countries.
Given the sample list of common character sets in the previous table and the number of languages that are required by a typical global PeopleSoft implementation, selecting a character set can be daunting, especially when you are planning to support a large list of languages.
To simplify this situation, an industry consortium of vendors devised a universal character standard: the Unicode standard. This internationally recognized character standard represents every character that is required to write virtually every written language. The Unicode standard was developed and is maintained by the Unicode Consortium in conjunction with ISO. This standard shares the character repertoire with ISO/IEC standard 10646: the Universal Multiple-Octet Coded Character Set (UCS), also known as the Universal Character Set for short.
The PeopleSoft system uses Unicode throughout PeopleTools to simplify character handling. The PeopleSoft system allows the use of Unicode within PeopleSoft databases to enable you to maintain a single database with characters from virtually any language.
The Unicode standard and the ISO 10646 standard are available from their respective organizations.
See The Unicode Consortium: http://www.unicode.org
See International Organization for Standardization (ISO): http://www.iso.org
Unicode Encodings
Unicode defines a code space of more than one million code points (or characters). Unicode code points are referred to by writing “U+” followed by the hexadecimal number—for example, U+0000, U+0061, U+FFFF, U+27741, and so on. To manage such a large repertoire of characters, Unicode defines multiple planes each comprising 65,533 code points, or character positions. Plane 0, covering the range of U+0000 to U+FFFF, is known as the Basic Multilingual Plane (BMP) and is generally sufficient for almost all modern languages. The other planes are intended to encode extended ideographic characters, archaic scripts, and other rarely used characters (such as advanced mathematical symbols). All characters from planes outside the BMP are known as supplementary characters.
PeopleTools fully supports the use of characters from the BMP only;supplementary character support is limited to display in PIA, storage in the database,and reporting output in BI Publisher. A tool that can be used to view Unicode character properties is http://www.unicode.org/charts/unihan.html. If a character is at codepoint U+20000 or higher, it is a supplementary character.
Several different Unicode encoding forms have been standardized based on two encoding methodologies. Unicode defines these two encoding methods: the Unicode Transformation Format (UTF), and UCS. An encoding maps the Unicode code points (or perhaps a subset of code points) to sequences of code values of some fixed size. In UTF encodings, the number in the encoding name indicates the number of bits per code value; in UCS encodings, the number indicates the number of bytes per code value.
Four common encodings of Unicode are widely used:
Other Unicode encodings—such as, CESU-8, Java’s Modified UTF-8, UTF-1, and others—have specific, and sometimes internal, applications and are not widely used for the interchange of information.
While the PeopleSoft system currently supports only the UTF-8 and UCS-2 encodings, the following table presents a brief comparison of all four common encodings:
Encoding
Description
Min. Bytes per Char.
Max. Bytes per Char.
PeopleSoft System Usage
UTF-32
The full, 32-bit (four-byte) encoding of Unicode. Each Unicode character is represented by a four-byte number. For example, the Latin small letter a character is represented in UTF-32 hexadecimal as 0x00000061. UTF-32 was formerly called UCS-4.
4
4
None
UTF-16
An extension of UCS-2 in which the application references characters on planes other than the BMP by combining two UCS-2 code units to designate a single, non-BMP character. UCS-2 is upward compatible with UTF-16 in that each UCS-2 character is also a valid character in UTF-16. However, UTF-16 allows characters outside the BMP to be referenced. These additional characters, known as supplementary characters, require two UTF-16 code units: a low surrogate and a high surrogate, together called a surrogate pair. When no supplementary characters are present, UTF-16 is identical to UCS-2.
2
4
None
UTF-8
A transformation of Unicode that encodes each character as one to four bytes, depending on which character is being encoded. All US-ASCII characters are encoded in UTF-8 as one byte, and this byte is identical to the encoding in US-ASCII. UTF-8 data is therefore backward compatible with US-ASCII data. All characters in the BMP are encoded as one, two, or three bytes in UTF-8. Characters in other planes are encoded as four bytes in UTF-8. UTF-8 has three main advantages: it is fully US-ASCII compatible, US-ASCII data can be considered as UTF-8 data, and it does not require that all characters use two or more bytes of storage.
1
4
The PeopleSoft system uses UTF-8 for serving HTML pages in the PeopleSoft Pure Internet Architecture and for inbound and outbound XML.
UCS-2
A 2-byte (16-bit) representation of each Unicode character. As such, it can reference only 65,535 code points and is limited to characters in the BMP.
2
2
The PeopleSoft system uses UCS-2 in memory for the Microsoft Windows development tools and for the application server.
Unicode Encoding Examples
This section includes Unicode encoding examples for the following characters:
Character
Unicode Code Point
Description
a
U+0061
Latin small letter a.
ñ
U+00F1
Latin small letter ñ.
U+20AC
Euro symbol
The following table shows the hexadecimal representation of these characters in each of the four Unicode encodings:
Unicode Encoding
Latin Small Letter a
(U+0061)
Latin Small Letter ñ
(U+00F1)
€ Symbol
(U+20AC)
UTF-32
0x0000006
0x000000F1
0x000020AC
UTF-16
0x0061
0x00F1
0x20AC
UTF-8
0x61
0xC3B1
0xE282AC
UCS-2
0x0061
0x00F1
0x20AC
See Also
Selecting Email Character Sets
Click to jump to top of pageClick to jump to parent topicNon-Unicode Character Sets
Although much of the PeopleSoft system runs by using Unicode, you can configure several components with a non-Unicode character set. When making these choices, you should understand the types of character sets other than Unicode that exist.
Note. For the sake of terminology, some systems, such as Microsoft Windows, refer to two types of character sets: Unicode and ANSI. ANSI, in this context, refers to the American National Standards Institute, which maintains equivalent standards for many national and international standard character sets. Informally, ANSI character sets refer to non-Unicode character sets, which can be any international, national, or vendor standard character set, such as those that are discussed at the beginning of this chapter.
Single-Byte Character Sets
Most character sets use one byte to represent each character and are therefore known as SBCSs. These character sets are relatively simple and can represent up to 255 unique characters. Examples of SBCSs are ISO 8859-1 (Latin1), ISO 8859-2 (Latin2), Microsoft CP1252 (similar to Latin1, but vendor specific), and IBM CCSID 37.
Double-Byte Character Sets
DBCSs use one or two bytes to represent each character and are typically used for writing ideographic scripts, such as Japanese, Chinese, and Korean. Most DBCSs allow a mix of one-byte and two-byte characters, so you cannot assume an even-string byte length. Encoding with a mix of one- and two-byte characters is also known as variable-width encoding, and such a character set is sometimes referred to as a multi-byte character set (MBCS).
The PeopleSoft system supports two types of DBCSs:
The difference between these types of DBCSs is in the way in which the system determines whether a particular byte represents one character or is part of a two-byte character.
Nonshifting DBCSs
Nonshifting DBCSs use ranges of codepoints, specified by the character set definition, to determine whether a particular byte represents one character or is part of a two-byte character.
In nonshifting DBCSs, the two bytes that are used to form a character are called lead bytes and trail bytes. The lead byte is the first in a two-byte character, and the trail byte is the last. Nonshifting DBCSs differentiate single-byte characters from double-byte characters by the numerical value of the lead byte. For example, in the Japanese Shift-JIS encoding, if a byte is in the range 0x81-0x9F or 0xE0-0xFC, then it is a lead byte and must be paired with the following byte to form a complete character.
The most popular client-side Japanese code page, Shift-JIS, uses this lead byte/trail byte encoding scheme, as do most Microsoft Windows and Unix/Linux ASCII-based double-byte character sets that represent Chinese, Japanese, and Korean characters. Contrary to its name, Shift-JIS is a nonshifting double-byte character set.
Shifting DBCSs
A shifting DBCS is another double-byte encoding scheme in use that doesn’t use the lead byte and trail byte concept. The IBM DB2 UDB for OS/390 and z/OS EBCDIC-based Japanese, Chinese, and Korean character sets use this shifting encoding scheme.
Instead of reserving a range of bytes as lead bytes, shifting DBCSs always keep track of whether they are in double-byte or single-byte mode. In double-byte mode, every two bytes form a character. In single-byte mode, every byte is a character in itself. To track what mode the character set is in, the system uses shifting characters. By default, the character set is expected as single-byte data. As soon as a double-byte character needs to be represented, a shift-in byte is added to the string. From this point on, all characters are expected to be two bytes. This continues until a shift-out byte is detected, which indicates that the character set should go back to single-byte per characters.
This scheme, while more complex than the lead byte and trail byte scheme, provides greater performance, because the system always knows how many bytes should be in any particular character. Unfortunately, it also increases the length of the string. For example, a character string that comprises a mixture of single-byte and double-byte characters requires more space to store in a shifting character set because you need to include the shift-in and shift-out bytes, as well as the data itself.
Click to jump to top of pageClick to jump to parent topicCharacter Sets in the PeopleSoft Pure Internet Architecture
PeopleSoft installations include multiple components, each of which must handle differing character sets.
PeopleSoft application servers and clients (for example, the PeopleTools development environment and PeopleSoft Pure Internet Architecture pages) use Unicode exclusively and do not rely on other character sets to represent and process data. However, depending on your environment, not all system components support Unicode-encoded data. Therefore, you might not be able to run all parts of your system in Unicode. For example, some database platforms and third-party products do not support Unicode. The following table illustrates support for Unicode in the PeopleSoft system.
Tier
Component
Unicode Support
Client
Yes
Yes
Application server
Application server
Yes
Database server
Non-Unicode DB (Western European or Japanese)
No
Unicode DB
Yes
Therefore, PeopleTools enables you to configure these system components to use other character sets:
When Unicode is not used for any of these types of operations or data storage, the PeopleSoft system transparently handles the conversion from Unicode to a non-Unicode character set. The non-Unicode character set that is used depends on several settings, which are discussed in detail later in this chapter.
The character sets that the PeopleSoft system supports are defined in the PSCHARSETS table. The following table lists these character sets and the names by which they may be referred to in PeopleSoft applications. You may need to know the correct character set name to use in several situations including:
PSCHARSETS
Character Set Name
Character Set Type
ANSI
Current ANSI-based code page.
Not really a character set, but causes the system to use the default non-Unicode character set of the host operating system.
SBCS or DBCS, depending on the host operating system.
ASCII
7–bit US-ASCII
SBCS
Big5
Big5 (Traditional Chinese)
Nonshifting DBCS
CCSID1027
IBM EBCDIC 1027 (Japanese-Latin)
SBCS
CCSID1047
IBM EBCDIC 1047 (Latin1)
SBCS
CCSID290
IBM EBCDIC 290 (Katakana)
SBCS
CCSID300
IBM EBCDIC 300 (Kanji)
Nonshifting DBCS
CCSID930
IBM EBCDIC 930 (Kana-Kanji)
Shifting DBCS
CCSID935
IBM EBCDIC 935 (Simplified Chinese)
Shifting DBCS
CCSID937
IBM EBCDIC 937 (Traditional Chinese)
Shifting DBCS
CCSID939
IBM EBCDIC 939 (Latin-Kanji)
Shifting DBCS
CCSID942
IBM EBCDIC 942 (Japanese PC)
Nonshifting DBCS
CP1026
Windows 1026 (EBCDIC)
SBCS
CP1250
Windows 1250 (Eastern Europe)
SBCS
CP1251
Windows 1251 (Cyrillic)
SBCS
CP1252
Windows 1252 (Western Europe)
SBCS
CP1253
Windows 1253 (Greek)
SBCS
CP1254
Windows 1254 (Turkish)
SBCS
CP1255
Windows 1255 (Hebrew)
SBCS
CP1256
Windows 1256 (Arabic)
SBCS
CP1257
Windows 1257 (Baltic)
SBCS
CP1258
Windows 1258 (Vietnamese)
SBCS
CP1361
Windows 1361 (Korean Johab)
SBCS
CP437
MS-DOS 437 (U.S.)
SBCS
CP500
Windows 500 (EBCDIC 500V1)
SBCS
CP708
Windows 708 (Arabic - ASMO708)
SBCS
CP720
Windows 720 (Arabic - ASMO)
SBCS
CP737
Windows 737 (Greek - 437G)
SBCS
CP775
Windows 775 (Baltic)
SBCS
CP850
MS-DOS 850 (Western Europe)
SBCS
CP852
MS-DOS 852 (Eastern Europe)
SBCS
CP855
MS-DOS 855 (IBM Cyrillic)
SBCS
CP857
MS-DOS 857 (IBM Turkish)
SBCS
CP860
MS-DOS 860 (IBM Portuguese)
SBCS
CP861
MS-DOS 861 (Icelandic)
SBCS
CP862
MS-DOS 862 (Hebrew)
SBCS
CP863
MS-DOS 863 (Canadian French)
SBCS
CP864
MS-DOS 864 (Arabic)
SBCS
CP865
MS-DOS 865 (Nordic)
SBCS
CP866
MS-DOS 866 (Russian)
SBCS
CP869
MS-DOS 869 (Modern Greek)
SBCS
CP870
Windows 870
SBCS
CP874
Windows 874 (Thai)
SBCS
CP875
Windows 875 (EBCDIC)
SBCS
CP932
Windows 932 (Japanese)
Nonshifting DBCS
CP936
Windows 936 (Simplified Chinese)
Nonshifting DBCS
CP949
Windows 949 (Korean)
Nonshifting DBCS
CP950
Windows 950 (Traditional Chinese)
Nonshifting DBCS
EBCDIC
IBM EBCDIC CCSID37 (USA)
SBCS
EUC-JP
Extended UNIX code (Japanese)
Nonshifting DBCS
EUC-KR
Extended UNIX code (Korean)
Nonshifting DBCS
EUC-TW
Extended UNIX code (Taiwan)
Nonshifting DBCS
EUC-TW-1986
Extended UNIX code (TW-1986)
Nonshifting DBCS
GB12345
GB 2312 (Simplified Chinese)
Nonshifting DBCS
GB18030
GB18030 (Simplified Chinese)
Nonshifting DBCS
GB2312
Nonshifting DBCS
HKSCS
Hong Kong Supplementary Character Set
Nonshifting DBCS
ISO-2022-JP1
ISO-2022-JP Japanese
Shifting DBCS
ISO-2022-KR
ISO-2022-JP Korean
Shifting DBCS
ISO_8859-1
ISO 8859-1 (Latin1)
SBCS
ISO_8859-10
ISO 8859-10 (Latin6)
SBCS
ISO_8859-11
ISO 8859-11 (Thai)
SBCS
ISO_8859-14
ISO 8859-14 (Latin8)
SBCS
ISO_8859-15
ISO 8859-15 (Latin9/Latin0)
SBCS
ISO_8859-2
ISO 8859-2 (Latin2)
SBCS
ISO_8859-3
ISO 8859-3 (Latin3)
SBCS
ISO_8859-4
ISO 8859-4 (Latin4)
SBCS
ISO_8859-5
ISO 8859-5 (Cyrillic)
SBCS
ISO_8859-6
ISO 8859-6 (Arabic)
SBCS
ISO_8859-7
ISO 8859-7 (Greek)
SBCS
ISO_8859-8
ISO 8859-8 (Hebrew)
SBCS
ISO_8859-9
ISO 8859-9 (Latin5)
SBCS
JIS_X0201
Japanese Half-width Katakana
Nonshifting DBCS
JIS_X_0208
Japanese Kanji
Nonshifting DBCS
Java
Java (Unicode encoding)
Unicode
Johab
Johab (Korean)
Nonshifting DBCS
Shift_JIS
Shift-JIS (Japanese)
Nonshifting DBCS
UCS2
Unicode UCS-2
Unicode
UTF-8
Unicode UTF-8
Unicode
UTF7
Unicode UTF-7. (An outdated Unicode 7-bit clean transformation that is sometimes used for email that must pass through gateways that do not support 8-bit characters.)
Unicode
UTF8
Unicode UTF-8
Unicode
UTF8BOM
Unicode UTF-8 with BOM (byte-order mark)
Unicode
This PeopleBook also contains information about supported character set encodings for globalization when using SQR for PeopleSoft.
See SQR for PeopleSoft-Supported Character Set Encodings.
1 To use certain Windows-31J (also known as Microsoft CP932) characters in incoming or outgoing email messages, you must complete additional configuration of your web server (incoming email) and application server or PeopleSoft Process Scheduler (outgoing email).
See Selecting Email Character Sets.
See Also
PeopleTools 8.52 Hardware and Software Requirements Guide
For more information and code charts for Microsoft code pages, visit http://msdn.microsoft.com/en-us/goglobal/bb964654.aspx
For more information and code charts for Unicode, visit http://www.unicode.org
Click to jump to parent topicSelecting Character Sets
This section discuses how to:
See Also
Click to jump to top of pageClick to jump to parent topicSelecting Database Character Sets
The primary character set decision that you must make when installing a PeopleSoft implementation is which character set to use for the database system. Ideally, all databases are encoded in Unicode; however, in some cases Unicode requires several bytes to represent each character when only one byte may be required in a non-Unicode character set. Therefore, the PeopleSoft system enables you to use certain non-Unicode character sets for the database.
By using a Unicode encoded database, you can maintain a single database with data in any combination of languages. A single PeopleSoft application server can serve multiple users connecting to the mixed-language database, regardless of the language or character set of those users’ client machines. The only restriction on a user’s ability to access mixed-language data is the capability of the user’s client workstation to interpret, display, and accept keyboard entry of the characters from the various languages.
Most language or region-specific non-Unicode character sets provide sufficient characters for only a few languages. If you create a non-Unicode database, you must ensure that all of the characters for all of the languages that you plan on using can be represented in the character set that you choose.
The following table lists whether a PeopleSoft language is supported in a Unicode or non-Unicode database character set:
Language Code
Language
ARA
Arabic
Unicode
BUL
Bulgarian
Unicode
CFR
Canadian French
CRO
Croatian
Unicode
CZE
Czech
Unicode
DAN
Danish
DUT
Dutch
ENG
US English
FIN
Finnish
ESP
Spanish
FRA
French
GER
German
HUN
Hungarian
Unicode
ITA
Italian
JPN
Japanese
KOR
Korean
Unicode
NOR
Norwegian
POL
Polish
Unicode
POR
Portuguese
ROM
Romanian
Unicode
RUS
Russian
Unicode
SER
Serbian
Unicode
SLK
Slovak
Unicode
SLV
Slovenian
Unicode
SVE
Swedish
THA
Thai
Unicode
UKE
English
ZHS
Simplified Chinese
Unicode
ZHT
Traditional Chinese
Unicode
Depending on the data that you store and how the database stores Unicode characters, a Unicode database can be significantly larger than a non-Unicode database. However, only the storage of character data is affected; the space that is required for non-character data, such as numbers and dates (which are stored by the database system as numbers), is not affected.
Depending on the database platform, you can use one of the four character set types (SBCS, nonshifting DBCS, shifting DBCS, or Unicode) when creating the database. However, the number of characters that you can store in each column is affected greatly by the type of character set that you choose for the database encoding.
See Also
PeopleTools 8.52 installation guide for your database platform
Your operating system and database guides
Click to jump to top of pageClick to jump to parent topicSelecting Application Server Character Sets
All data that is stored in memory and processed by the PeopleTools application server is held in Unicode. However, the application server allows files on the server (created through PeopleCode file layout objects) and log and trace files to be Unicode or non-Unicode. Although the PeopleSoft application server uses Unicode internally for all data processing, it can create these files in Unicode or in a non-Unicode character set.
Each PeopleSoft application server is configured with a default non-Unicode character set. If a file operation must create a non-Unicode file, this character set is used, unless another character set is explicitly specified in the file operation. For example, if you create a file layout object to write a non-Unicode file, but you don’t specify in which character set the file should be created, the default non-Unicode character set of the application server is used.
Microsoft Windows enables you to change the default character set of the system, although as installed, the default character set matches the default locale of the Microsoft Windows installation. To change the system default locale (and therefore the character set), on Microsoft Windows servers, use the Control Panel’s Regional Options menu. In the Language settings for the system section, click the Set Default button.
When running on Unix/Linux, the PeopleSoft application server enables you to specify the default non-Unicode character set in the application server’s configuration file, which you select by using the PSADMIN tool. Any valid PeopleSoft character set with a character set type of SBCS or nonshifting DBCS is a valid default non-Unicode character set for PeopleSoft application servers that run on Unix/Linux.
See Also
Attachments with non-ASCII File Names
Click to jump to top of pageClick to jump to parent topicSelecting and Managing Client Workstation Character Sets
You must consider the client components of PeopleTools when you are planning your language strategy. The requirements for language support on client workstations are different, depending on whether you are using the PeopleSoft Pure Internet Architecture or the PeopleTools development tools for Microsoft Windows.
Character Sets and Fonts in the PeopleSoft Pure Internet Architecture
The PeopleSoft Pure Internet Architecture serves all HTML pages in the UTF-8 encoding of Unicode. This encoding is recognized automatically by the web browser, because the encoding of the page is announced in the HTTP header when the browser communicates with the web server. All browsers supported by PeopleTools can support UTF-8 encoded HTML pages.
However, the browser needs other components to correctly display and enter the vast array of characters that are available in Unicode. Specifically, you need appropriate fonts to display the various scripts in which you expect data to be maintained. In addition, you might need alternate keyboard layouts or, in the case of ideographic scripts such as Chinese, Japanese, and Korean, you need input method editors (IMEs) to convert sequences of keystrokes into ideographs. The requirement for alternate keyboard and IMEs is the same for both the PeopleSoft Pure Internet Architecture and the PeopleTools development environment.
Not all fonts contain a full repertoire of Unicode characters, because many fonts are tailored to address a specific list of languages and contain only the glyphs that are required by those languages. If you try to view Unicode data with a font that does not contain the appropriate characters for the displayed language, you will most likely see square boxes in place of the appropriate characters. The data has not been corrupted; there is just no glyph available in the current font for the character that the system is trying to display. For this reason, you may need to license or configure several fonts for a global PeopleSoft system.
The PeopleSoft Pure Internet Architecture includes a set of style sheets, defined with Application Designer, that determine the font that is used to display HTML pages. In some cases, the application data may contain characters that are not present in this font and that require a different font.
The Albany TrueType fonts shipped in the PS_HOME\fonts\truetype directory support all of the languages supported by the PeopleSoft system. Alternatively, you may need to obtain and configure fonts that contain the characters for the languages that you are planning to use, if your workstations are not already configured with these fonts. Obtain fonts from the following sources:
Depending on your browser, you can also download fonts from your browser’s manufacturer.
To enable the display of GB18030 characters, you can use either the SimSun-18030 font from Microsoft or the Albany fonts shipped in the PS_HOME\fonts directory. Both of these fonts have glyphs for the supported ranges of the GB18030 character set.
Fonts and the PeopleTools Development Environment
PeopleTools enables you to specify the font that is used for all graphical components for all PeopleTools modules that run on Windows, such as Application Designer. Use these methods to specify fonts:
Input Methods
If users will enter translated data by using PeopleSoft Pure Internet Architecture or the PeopleTools development environment, you must ensure that an appropriate keyboard layout or input method editor is installed on the workstation.
Most alphabetic languages can be typed by using a relatively simple keyboard layout. Several specialized keyboard layouts exist for most languages; configure these keyboard layouts through your operating system. For example, a Spanish keyboard layout contains keys for the n-tilde character (ñ) and several other accented characters.
However, certain PeopleSoft hot keys do not work as expected on alternate, non-U.S. keyboard layouts. For example, Alt+', Alt+\, and Alt+/ do not produce the expected results on the AZERTY keyboard. This occurs because some keys on non-U.S. keyboards produce different key codes than the same key on a U.S. keyboard (also known as a QWERTY keyboard).
A solution to this problem can be found in the appendix.
See PeopleSoft Hot Keys Do Not Function As Expected on a non-U.S. Keyboard.
There are several ways of entering these characters by using a nonlocalized keyboard. Your operating system manual can help you use specialized keyboard layouts, such as the English international layout, which enables you to enter accented characters by using two keystrokes. The Microsoft web site contains information about keyboards that are supported by Microsoft Windows and instructions for installing and configuring Windows keyboard layouts.
Ideographic languages, such as Chinese, Japanese, and Korean, require the use of a front-end processor to intercept multiple keyboard strokes and transform them into an ideographic character. These are known as IMEs, and they must be installed on each workstation where you plan to enter the ideographic languages.
Most localized versions of operating systems for these languages come preconfigured with IMEs that are appropriate for the language that is supported by the operating system. But on systems where the default locale is not Chinese, Japanese, or Korean, you may need to configure or license an IME from a third-party vendor. The PeopleSoft Pure Internet Architecture supports any IME that is supported by your browser. The designer tools in Microsoft Windows support all standard Microsoft IMEs.
Click to jump to top of pageClick to jump to parent topicSelecting Email Character Sets
The PeopleSoft system supports UTF-8 for outgoing Simple Mail Transfer Protocol (SMTP) email messages from PeopleTools application servers. In addition, the PeopleSoft system supports several additional encodings for outgoing email.
PeopleSoft application servers support the following for outgoing email:
Specifying Email Character Sets
You specify an email character set in the SMTPCharacterSet parameter in the application server configuration file, psappsrv.cfg. By default, the SMTPCharacterSet parameter is set to UTF-8.
Note. You should specify a value for the SMTPCharacterSet. If you do not specify a value for the parameter, email is sent as-is, with no encoding. Leave the parameter set to the default value of UTF-8 if you are not certain about which value to use.
For example, to use ISO-2022-JP encoding for outgoing SMTP mail, in the psappsrv.cfg file, set the SMTPCharacterSet parameter to ISO-2022-JP, as shown in the following example:
[SMTP Setting] ... SMTPCharacterSet=ISO-2022-JP SMTPEncodingDLL=blank
You can also write your own SMTPEncodingDLL modules, if necessary.
Using Extended Japanese Characters
To use certain Windows-31J (also known as Microsoft CP932) characters—specifically, NEC special characters, NEC-selected IBM extended characters, IBM extension characters, and user-defined characters—in incoming or outgoing email messages with the ISO-2022-JP Japanese character set, you must complete additional configuration of your web server (for incoming email) and application server or PeopleSoft Process Scheduler (for outgoing email).
For incoming email on the web server, the following JVM setting must be added to the JAVA_OPTIONS_WIN32 parameter in the setenv.cmd file:
SET JAVA_OPTIONS_WIN32= "-Dsun.nio.cs.map=x-windows-iso2022jp/ISO-2022-JP"
For outgoing email on the application server or PeopleSoft Process Scheduler, the following JVM option must be added to either the psappsrv.cfg file or the psprcs.cfg file depending on whether the application server or an AE program, respectively, will be handling outgoing email messages. JVM options are set in the PSTOOLS section of the file:
[PSTOOLS] ... JavaVM Options=-Dsun.nio.cs.map=x-windows-iso2022jp/ISO-2022-JP
In addition, your web server, application server, and PeopleSoft Process Scheduler must be using a Java Runtime Environment (JRE) or Java Development Kit (JDK) that is supported for extended Japanese characters. See the release notes on My Oracle Support website.
See My Oracle Support, Knowledge, Tools and Technology, Documentation, Release Notes.
Click to jump to parent topicConverting Between Character Sets
You can use PeopleCode file functions to convert files or text strings from one supported PeopleSoft character set to another supported PeopleSoft character set.
PeopleCode operations such as GetFile, GetTempFile, Open, ReadLine, and WriteLine automatically account for the file encoding. Therefore, you can:
When using a character set such as UCS2 or UTF8BOM, the BOM is added at the beginning of the file contents when using WriteLine. The BOM is skipped when read by the ReadLine PeopleCode function, and not interpreted as a text character. Since the BOM is recognised as meta data and not part of the file's text the BOM is not added to file contents when writing in a non-Unicode character set with the WriteLine PeopleCode function.
In the following example PeopleCode program, the FileEncodingConversion function handles converting files from one supported character set to another. In the body of the program, the function is called to convert from the UTF8BOM character set to the UCS2 character set.:
REM this function, FileEncodingConversion() converts character encoding of input file to another of output file. REM an example of how to call the function is at the end of this file. Local File &InputFile, &OutputFile; Local string &InputDirFile, &OutputDirFile, &InputFilename, &OutputFilename; Local string &sDirSep, &LogLine; Local array of string &FIleEncoding; Local boolean &ret; Function FileEncodingConversion(&InputEncoding, &InputDirectoryFile, &OutputEncoding, &OutputDirectoryFile) Returns boolean &InputFile = GetFile(&InputDirectoryFile, "R", &InputEncoding, %FilePath_Absolute); &OutputFile = GetFile(&OutputDirectoryFile, "W", &OutputEncoding, %FilePath_Absolute); If &InputFile.IsOpen And &OutputFile.IsOpen Then While (&InputFile.readline(&LogLine)) &OutputFile.Writeline(&LogLine); End-While; &InputFile.Close(); &OutputFile.Close(); Return True; Else If &InputFile = Null Then WinMessage("Error: PeopleCode: File Encoding I/O: " | "Failed to open: " | &InputFile.Name); Else If &OutputFile = Null Then WinMessage("Error: PeopleCode: File Encoding I/O: " | "Failed to open:" | &OutputFile.Name); End-If; End-If; Return False; End-If; End-Function; /*-----------------------------------------------------------------------*/ /* Function IsUnix */ /* check if OS = Unix */ /*-----------------------------------------------------------------------*/ Function IsUnix Returns boolean &DummyFile = GetFile("/bin/sh", "E", %FilePath_Absolute); If &DummyFile.IsOpen Then; &DummyFile.Close(); Return True; Else; Return False; End-If; End-Function; REM test the function above; &FIleEncoding = CreateArray("UTF8BOM", "UCS2", "SJIS", "GB18030", "UTF8", "a",⇒ "u"); REM WinMessage("ret: " | &ret); If IsUnix() Then /* for UNIX */ &ret = FileEncodingConversion(&FIleEncoding [1], "/home/FS_" | &FIleEncoding [1] | ".txt", &FIleEncoding [2], "/home/BEFORE/FS_PCode_" | &FIle⇒ Encoding [1] | "_to_" | &FIleEncoding [2] | ".txt"); Else /* for WINDWOS */ &ret = FileEncodingConversion(&FIleEncoding [1], "D:\TMP\FS_" | &FIleEncoding [1] | ".TXT", &FIleEncoding [2], "D:\TMP\AFTER\FS_PCode_" | &FIleEncoding [1] | "_to_" | &FIleEncoding [2] | ".TXT"); End-If
Click to jump to parent topicValidating Field Length
This section provides overviews of Application Designer field length semantics and field length checking for non-Unicode databases and discusses how to enable or disable data field length checking.
Click to jump to top of pageClick to jump to parent topicUnderstanding Application Designer Field Length Semantics
The database character set determines the way that PeopleTools interprets the column length that is defined in Application Designer.
If you create a Unicode database, the field length, as shown in Application Designer, indicates the maximum number of Unicode BMP characters that are permitted in the field, regardless of the Unicode encoding that is used by the database. Some database platforms, such as Oracle with byte semantics, use byte lengths to measure column sizes when operating in a Unicode database, while others use character lengths.
When the database uses byte-sized column lengths, the PeopleSoft system sizes the database columns based on the worst-case ratio between bytes and characters in the Unicode encoding that is used by your database. For example, if the AL32UTF8 character set is used by Oracle with byte semantics, the worst-case character-to-byte ratio when running against an Oracle Unicode database is 1:3. So, column size is tripled when creating a Unicode database on Oracle. A field that is defined in Application Designer as a CHAR(10) is created on an Oracle Unicode database with a type of VARCHAR2(30). This tripling of the maximum column size does not affect the actual size of the database, because variable length character fields do not reserve space in the database.
Other database platforms use character-based column lengths whose sizes represent the maximum number of Unicode characters instead of bytes that may be stored. Examples of this implementation are the NCHAR data type in Microsoft SQL Server and the GRAPHIC data type in DB2 UDB for Linux, Unix, and Microsoft Windows.
If you create a non-Unicode database, the field length in Application Designer represents the number of bytes that are permitted in the field, based on the character set that you used to create the database. Therefore, a PeopleSoft Unicode database enables you significantly more space for character data within the database when dealing with ideographic languages, such as Japanese, that require more than one byte storage per character.
The following tables show some of the possible database encodings for database platforms that the PeopleSoft system supports in Unicode and DBCS and their effects on database column sizes. Each table shows the database representation and the worst case number of characters allowed in the character field for a character field defined in Application Designer with a length of 10.
This table shows the information for an Oracle database with byte semantics (used by PeopleSoft 8.9 applications and earlier):
Database Representation
Number of Characters
Unicode (AL32UTF8)
VARCHAR2(30)
10
Any SBCS
VARCHAR2(10)
10
Shift-JIS (JA16SJIS or JA16SJISTILDE)
VARCHAR2(10)
5
This table shows the information for an Oracle with character semantics (used by PeopleSoft 9.0 applications and later):
Unicode (AL32UTF8)
VARCHAR2(10)
10
Any SBCS
VARCHAR2(10)
10
VARCHAR2(10)
10
This table shows the information for an Microsoft SQL Server database with VARCHAR semantics:
Unicode (UCS-2)
NVARCHAR(10)
10
Any SBCS
VARCHAR(10)
10
Shift-JIS (CP932)
VARCHAR(10)
5
This table shows the information for a Microsoft SQL Server database with CHAR semantics:
Unicode (UCS-2)
NCHAR(10)
10
Any SBCS
CHAR(10)
10
Shift-JIS (CP932)
CHAR(10)
5
This table shows the information for a DB2 UDB for OS/390 and z/OS database:
Any SBCS
CHAR(10)
10
Shifting DBCS (CCSID 930/939)
CHAR(10)
4 (4 x 2 byte characters, plus shift-in & shift-out bytes)
This table shows the information for all other databases:
Any SBCS
CHAR(10)
10
Click to jump to top of pageClick to jump to parent topicUnderstanding Field Length Checking for Non-Unicode Databases
The maximum number of characters that are permitted in a PeopleSoft field varies, depending on the character set of the database. Because all components of PeopleTools use Unicode for internal storage, by default, field length checking occurs in terms of Unicode character counts. This calculation is appropriate for Unicode databases and for any SBCS databases.
However, if you are using a non-Unicode DBCS, special length checking must occur each time you move off a field to ensure that the string that you entered fits in the database column when the string is converted to the database’s character set.
For graphically sizing page fields, PeopleTools uses the Unicode length of the field as defined in Application Designer. For example, if a field is defined in Application Designer as a 10-character field, page fields in both the PeopleSoft Pure Internet Architecture and the PeopleTools clients for Microsoft Windows allow 10 characters to be displayed unless manually resized by the developer.
However, if the database is encoded in a non-Unicode DBCS character set, such as Japanese Shift-JIS or IBM CCSID 930/939, special length validation must occur because the database column size is created relative to a byte count, not to a character count as is used by the simple field length validation.
For example, if a user enters 10 Japanese characters into a field that is defined as CHAR(10) in Application Designer, this string needs 20 bytes of storage in a nonshifting DBCS character set and 22 bytes of storage in a shifting character set. This 10-character input would fail insertion in both of these databases.
To address this issue, the page processor checks the Data Field Length Checking option on the PeopleTools Options page and performs character-set specific length validation against the contents of each field when the field is validated. Typically length validation occurs when the field’s FieldChange PeopleCode event fires, so the actual time of validation may differ, depending on whether your page uses deferred mode processing.
Click to jump to top of pageClick to jump to parent topicEnabling or Disabling Data Field Length Checking
To enable or disable data field length checking:
  1. Select PeopleTools, Utilities, Administration, PeopleTools Options.
    The PeopleTools Options page appears.
  2. From the Data Field Length Checking drop-down list box, select a value based on the character set that you are using for the database:
    Others
    Select if you are using a Unicode encoded database or a non-Unicode SBCS database. This option prevents special field length checking, which is not required by these types of databases.
    DB2 MBCS
    Select DB2 MBCS if you are running a Japanese database on the DB2 UDB for Linux, Unix, and Microsoft Windows platform. This options enables field length checking based on a shifting DBCS.
    MBCS
    Select if you are running a non-Unicode Japanese database on any other platform. This option enables field length checking based on a nonshifting DBCS.
    Note. The non-Unicode DBCS settings are specifically oriented to Japanese language installations, because Japanese is the only language that the PeopleSoft system supports in a non-Unicode DBCS encoding. All languages other than Western European languages and Japanese are supported by the PeopleSoft system only when using Unicode encoded databases.
  3. Click the Save button.
Click to jump to parent topicUsing CJK Ideographic Characters in Name Character Fields
This section discusses PeopleSoft standard name conventions, including name conventions for Chinese, Japanese, and Korean (CJK) ideographic characters. PeopleSoft standard name conventions apply when data is entered or displayed in character fields that use Name as the format type. These conventions should be used when a complete name is constructed from multiple name character fields or when all name data is entered into a single name character field.
The PeopleSoft standard name convention is:
[lastname] [suffix],[prefix] [firstname] [middle name/initial]
Examples of typical suffixes include degrees, affiliations, and titles such as MD, PhD, Jr., and III. Examples of typical prefixes include titles and honorifics such as Ms., Mr., Dr., Rev., and Hon.
Valid examples of these conventions include:
Name as Displayed by PeopleSoft Convention
Name Elements Used
Actual Name
O’Brien,Michael
[lastname],[firstname]
Michael O’Brien
Jones IV,James
[lastname] [suffix],[firstname]
James Jones IV
Phillips MD,Deanna Lynn
[lastname] [suffix],[firstname] [middle name]
Deanna Lynn Phillips, MD
Reynolds Jr.,Dr. John Q.
[lastname] [suffix],[prefix] [firstname] [middle initial]
Dr. John Q. Reynolds Jr.
Phipps-Scott,Ms. Adrienne
[lastname],[prefix] [firstname]
Ms. Adrienne Phipps-Scott
Knauft,Günter
Günter Knauft
However, if the name contains any CJK ideographic characters, different standard name conventions apply.
If the name contains any Japanese or Korean ideographic characters, the first and last names are separated by a space instead of a comma. In Japanese, a prefix or suffix is optional; in Korean, only an optional prefix can be used. These modified PeopleSoft standard name conventions can be used when a name includes any of the following types of characters:
The PeopleSoft standard name convention for Japanese names including these ideographic characters is:
[lastname] [firstname][{suffix|prefix}]
The PeopleSoft standard name convention for Korean names including these ideographic characters is:
[lastname] [firstname][prefix]
Name Elements Used
English Equivalent
塩次 伸二
Shinji Shiotsugu
塩次 伸二様
Mr. Shinji Shiotsugu
홍 길동
Hong Gildong
홍 길동씨
Mr. (or Ms.) Hong Gildong
If the name contains Chinese Hanzi, there is no space or comma between the first name, last name, suffix, and prefix. The PeopleSoft standard name convention for names including Chinese Hanzi characters is:
[lastname][firstname][{suffix|prefix}]
Valid examples of this convention include:
Name Elements Used
English Equivalent
陳嘉明
Chan Ka Ming
陳嘉明先生
[lastname][firstname][prefix]
Mr. Chan Ka Ming
See Also
Specifying Character Field Attributes
Character Processing
Click to jump to parent topicDetecting and Converting Between Character Types
PeopleTools also provides PeopleCode string functions that recognize and convert between different characters within the Japanese character set. This enables you to detect, convert, and enforce the types of characters that you can enter in any PeopleSoft field. For example, the PeopleSoft system uses these functions in the development of the Alternate Character Architecture in some PeopleSoft applications. The Alternate Character Architecture is used in several PeopleSoft applications to provide a feature that enables the entry of, and enforces the characters contained in, Japanese phonetic spellings (Furigana) by using the Hiragana or Katakana scripts.
The following PeopleCode string functions can be used to recognize and convert between different characters within the Japanese character set:
See Also
CharType
