This chapter discusses how to:
Add a node definition to the system.
Configure a node.
Ping a node.
Rename or delete a node.
Understanding Nodes
Nodes represent any organization, application or system that will play a part in integrations.
For example, nodes can represent customers, business units, suppliers, other trading partners, external or third-party software systems, and so on.
Node definitions define the locations to or from which messages can be routed.
Because an application can send messages to itself, a default local node definition that represents the application is delivered as part of the integration engine.
Each PeopleSoft installation must have one, and only one, default local node
Local and Remote Nodes
Each PeopleSoft Integration Broker database involved in an integration must contain a default local node definition for itself, and a remote node definition for each of the other nodes involved.
Local and remote nodes are concepts relative to the database in which the nodes are defined. If you’re signed on to Database A which has Node A defined, then Node A is local. If you’re signed on to Database B, Node A is defined as remote.
For example, if the following definitions exist in the Node A database:
NODE_A (default local)
NODE_B (remote)
The following definitions must exist in the Node B database for it to integrate with Node A:
NODE_A (remote)
NODE_B (default local)
In practice, only portals use nodes designated simply as Local. The only local node definition used by PeopleSoft Integration Broker is the one designated Default Local, which represents the database onto which you are signed.
PeopleTools-Delivered Nodes
This section discusses nodes that are delivered with PeopleTools.
The AIA node is used for Oracle Application Integration Architecture (AIA) integrations, and represents an AIA integration partner.
Warning! Do not modify or delete the AIA node.
The Anonymous node is designated as the requesting node within PeopleSoft Integration Broker for third-party integrations that do not pass in a requesting node, but do have a defined any-to-local routing definition enabled on the service operation to be invoked.
Warning! Do not delete the Anonymous node.
You must modify the Anonymous node and define a Default User ID. The Default User ID that you specify is the ID that the system assigns to transactions that do not pass in a user ID.
The Atom node is used in association with PeopleTools feeds functionality.
You can use the Atom node only with asynchronous service operations. You cannot use the Atom node as the sending node. When the Atom node is the receiving node, the sending node must be the default local node.
Warning! Do not delete the Atom node.
Feeds are described elsewhere in PeopleBooks.
See Feed Publishing Framework Preface.
PeopleSoft delivers a node with the name BPEL specifically for integrations with BPEL process-based integrations when you are using Oracle BPEL Process Manager as the runtime engine. If you are using Oracle BPEL Process Manager, you must configure this node.
Information about configuring this node is described elsewhere in PeopleBooks.
See Configuring the PeopleSoft-Delivered BPEL Node.
The Default Local Node represents the system on which the application database is installed.
PeopleSoft Integration Broker is delivered with one node predefined as the default local node. You can't change which node is the default local node, but you can rename it to a more appropriate and meaningful name for your application or system.
The WSDL node is the default node used by the Consume Web Service wizard.
Warning! Do not modify or delete the WSDL node.
The WADL node is the default node for REST consumer services.
Warning! Do not delete the WADL node.
Prerequisites for Adding and Configuring NodesTo configure a node and its associated transactions, at least one gateway with one connector must be defined.
See Defining Integration Gateways, Loading Target Connectors.
Adding Node DefinitionsThis section discusses how to add a node definition to the system.
Adding a Node DefinitionThe following example shows the Nodes-Add a New Value page.
Note. The name you specify for a remote node must be the same as the name it specifies for itself.
To add a node:
Select PeopleTools, Integration Broker, Integration Setup, Node Definitions.
Click the Add a New Value tab.
In the Node Name field, enter a name for the node, keeping in mind that node names must begin with a character and may contain up to 30 characters.
Click the Add button to define the node.
The Node Definitions tab displays.
Configuring Nodes
Define node parameters.
Specify contact information.
Define node properties.
Specify node gateways and connectors.
Defining Node ParametersAccess the Node Definitions page (PeopleTools, Integration Broker, Integration Setup, Nodes).
The previous example shows the node definition for the node QE_LOCAL, the default local node.
The following example shows the node definition for the node QE_EXTERNAL, an External type node.
Specifying Contact Information
Click the Contacts/Notes link to access the Node−Node Contacts/Notes page.
Each node represents a database or other software entity managed by one or more people. Use this page to record information about the people associated with the current node.
The name of the representative or administrator of the node, in standard PeopleSoft name format. |
Contact Email |
The Contact Manager’s email address, in standard PeopleSoft email address format. |
Contact Phone Number |
The phone number of the contact manager. |
Contact URL |
The address of the Contact Manager’s support web site, if there is one. |
Defining Node Properties
Click the Properties link to access the Node − Properties page.
This page provides a convenient place to store additional information about the current node that can be referenced by any other node. Properties created for all nodes are stored in a single table, PSNODEPROP.
Examples include a DUNS number or Tax Identification Number. These properties can be used to update messages with additional information. They can also serve to add additional categorization for custom processing; for example, add a Region property so nodes can be referenced by region for special processing.
Name Type |
Select from: Category: The property is used for categorization. Ident: The property is used for identification. Search: The property is used for searching. |
Property Name |
Enter a new property name or select an existing property of the selected name type. |
Specifying Gateways and Connectors
Select the Connectors tab to access the Node − Connectors page.
Use this page to specify the integration gateway and target connector the node uses for integrations.
At least one gateway with at least one target connector must be defined and configured. If the current node is remote, it can use the default local node’s gateway or any other installed gateway as its local gateway. If the current node has its own gateway installed, the default local node’s database must contain a definition for it, configured as a remote gateway.
Specifying a Gateway and Target Connector for the Current Node
To specify a gateway and connector for the current node:
From the Gateway ID field, click the Lookup button to select the gateway ID for the gateway you want the current node to use.
When the default local node sends a message to any other node, the message first goes to the default local node’s local gateway through its PeopleSoft listening connector, regardless of the gateway ID you select here.
If you specify a remote gateway ID, the local gateway uses its default remote gateway connector (specified in the integrationGateway.properties file) to route messages to the remote gateway through the remote gateway’s PeopleSoft listening connector. The remote gateway sends the messages directly to the current node, using the connector you specify in the next step.
Note. The default remote gateway connector setting initially specifies the HTTP target connector, which is unlikely to change unless you develop a custom target connector.
If you specify the local gateway ID, the local gateway sends messages directly to the current node, using the connector you specify in the next step.
From the Connector ID field, select a connector ID from the list of connectors registered with the selected gateway.
Specify the target connector appropriate to the communication method preferred by the current node. If the node is a PeopleSoft application with Integration Broker installed, select PSFTTARGET. If the node is a PeopleSoft 8.1x application, select PSFT81TARGET.
The rows on the Properties and Data Type/Description tabs are automatically populated with the connector’s properties that are designated Required in the gateway definition. The fields on these tabs are the same as those on the Connector Properties page. If the connector has multiple instances of a required property defined, only the instance designated as Default appears.
From the Delivery Mode drop-down list box, select a delivery mode. The options are:
Guaranteed. (Default.)
Best Effort.
These options are discussed in detail elsewhere in this PeopleBook.
Click the Save button.
Note. You can override the gateway and connector selection for individual outbound transactions.
Working With Connector Properties
Properties that appear on this page are copies of the specified connector’s required properties. The following example shows the node definition configured with the HTTP target connector (HTTPTARGET). The default properties for this connector appear in the Properties grid.
You can use this page to:
Add an instance of a non-required property.
Add a new instance of a required property.
Modify the value or description of a property instance.
Remove a property instance.
Information about appropriate modifications might come from PeopleSoft, from the connector’s developer, or from your own experience and requirements.
Important! Don’t remove a required property unless you replace it with another instance of the same property. Without all of its required properties, the connector is unlikely to work correctly.
You must encrypt any password connector property values. The Connector tab features access to the Password Encryption Utility that enables you to encrypt a password value and paste it into the appropriate field on the page. To access the utility, click the Password Encryption Utility arrow.
Accessing the Integration Gateway Properties File
The Connectors tab features a Gateway Setup Properties link you can use to access the integrationGateway.properties file directly from this tab.
Testing Connector Configurations
The Connectors tab features a Ping Node button you can use to test your configuration.
If the ping is successful, a window displays with a message indicating that the gateway is active and the PeopleTools version that you are running. If the ping is not successful, a window displays with a message indicating the gateway could not be found.
See Also
Pinging NodesThis section discusses how to:
Ping a node using the Nodes–Connectors page.
Ping a node using the Node Status page.
Understanding Pinging NodesThis section describes the processing that takes place when you ping a node from the PeopleSoft Pure Internet Architecture.
The system uses the application server URL, user ID and password specified in the Jolt connect string settings section in the integration gateway properties file to establish a connection to the target database.
The system verifies that the user ID and password are valid on the target system.
The destination node must match the defined local node on the target system, otherwise the system displays the following error:
Destination node does not match local node.
When pinging remote nodes, if the source node defined on the target is defined as a PeopleSoft node and an authentication token is passed, then the authentication option on the node must be either Node Password or Certificate. The system then compares the passwords or certificate.
In the following cases, if node authentication is defined, you cannot ping a node:
The source node defined on the target system is not a PeopleSoft node.
The source node defined on the target system is a PeopleSoft node, but no authentication option, for example Node Password or Certificate, is selected.
Pinging Nodes Using the Nodes-Connectors PageYou can ping a node using the Nodes-Connector page in PeopleSoft Integration Broker.
To ping a node:
Access the Nodes-Connectors page (select PeopleTools, Integration Broker, Configuration, Nodes, and click the Connectors tab).
Click the Ping Node button.
Pinging Nodes Using Node Status PageYou can ping a node using the Node Status page in the Service Operations Monitor.
To ping a node:
Access the Node Status page (select PeopleTools, Integration Broker, Service Operations Monitor, Administration, Node Status).
See Also
Pausing, Testing, and Pinging Nodes
Renaming or Deleting Nodes
This section discusses how to rename and delete nodes.
Understanding Renaming and Deleting NodesThis section discusses how to rename and delete nodes.
There are several situations in which you might need to rename or delete a node definition. When you do so, PeopleSoft Integration Broker automatically handles most of the dependencies involved — such as deleting routings and other properties associated with the node.
However, the live message data in Integration Broker Monitor remains unchanged. If that data still contains references to the node you want to modify, Integration Broker will prevent you from making the modification. You must remove all data from the live message tables before you can rename or delete the node definition.
You cannot delete the default local node or a node that hosts a portal. As a result, the Delete Node button is hidden on these node definitions.
Note. If you upgraded your PeopleSoft application from a PeopleTools 8.1x release, the newly created default local node definition must be renamed, so you must first remove any remaining live message data if you didn’t do so before the upgrade.
Renaming or Deleting a NodeRenaming or deleting a node requires the following actions:
Deactivate all the domains in your messaging system.
Access the Domain Status page.
For each active domain in the system, from the Domain drop-down list box, select Inactive.
Click Update to change the status of all domains to Inactive and all dispatchers to Cleanup.
Click Force Reset to change the status of all dispatchers to Inactive.
Remove the data from the live message tables.
You have several choices when removing data from the live message tables:
You can archive messages one at a time from the Asynchronous Details or Synchronous Details component.
You can archive messages with a batch process using the Archive Monitor Data component.
You can purge message data using one of several Data Mover scripts delivered with PeopleSoft Integration Broker. You'll find them in PS_HOME\scripts:
AppMsgPurgeLive.dms |
Deletes the queue data from every live message table in the database. |
AppMsgPurgeAll. |
Deletes the message data from every live message table and every archive message table in the database. This is the recommended procedure when upgrading from earlier versions of PeopleTools, because the archived data is largely incompatible with the new release. |
Rename or delete the desired node definition.
If you are renaming the default local node, note that the name cannot exceed 15 characters. Other node names can contain up to 30 characters.
Reboot the web server.
Reactivate the messaging domains.
Access the Domain status page.
On the Domain Status page, select All Domains Active.
Click Update to change the status of all domains and dispatchers to Active.
See Also
Running Batch Service Operation Archiving Processes
Purging Runtime Service Operations Monitor Tables
Understanding Data Mover Scripts
