This chapter provides an overview of system and server administration and discusses system and server administration implementation.
System and Server Administration OverviewThis section discusses:
PSADMIN.
Analytic servers.
Web servers.
Verity Search indexes.
PeopleSoft Configuration Manager.
PeopleTools utilities.
Tracing and debugging.
Jolt Internet Relay.
Timeout settings.
PSADMIN
You use PSADMIN for managing application server domains, PeopleSoft Process Scheduler domains, integration server processes, search domains, and so on. PSADMIN also enables you to configure and manage the behavior of servers with respect to a wide range of PeopleTools infrastructure elements, including:
Tuxedo and Jolt.
PeopleCode debugging.
Caching.
Analytic server framework.
Transactional SQL requests.
Performance enhancement.
PeopleSoft Query.
Integration Broker.
Email.
Real time event notification.
Performance Monitor.
MultiChannel Framework.
You launch and run PSADMIN using a command line interface.
See Also
Setting Application Server Domain Parameters
Analytic Servers
The analytic server framework provided by PeopleSoft is a general server infrastructure designed to meet the needs of PeopleSoft products that process large amounts of data in memory. It provides a stateful model of client/server connectivity that these products require to be part of the PeopleTools system, by keeping track of configuration settings, transaction information, and other data for a session. For example, client software could request that an analytic model or optimization model be recalculated in one transaction, then retrieve the results of the calculation on that model at a later time. A server process handles these requests, and maintains the model state and calculated data in memory between the requests. Additional transactions can then modify the model and perform recalculations on it without shuffling all of the data between the client and the server or dumping all the data to a database, thus preserving in-memory performance.
When a program doesn't “maintain state” or when the infrastructure of a system prevents a program from maintaining state, it’s known as a stateless program or system. It can’t take information about the last session into the next session, such as settings the user makes or conditions that arise during processing. All session state is maintained by the client and is transferred to the server with each request. As long as an application server is up and running, a user’s session remains active and functional, and any application server can perform requested transactions.
However, with some products, such as Analytic Calculation Engine or PeopleSoft Optimization Framework, running a calculation on a multi-dimensional model is likely to produce far more data than is reasonable to shuttle between a client and server to maintain a stateless connection. For performance reasons, the calculations are performed completely in memory. If these calculations were to be synchronized and stored in the database so that a stateless connection could be maintained, performance would suffer significantly.
Web Servers
PeopleSoft supports Oracle WebLogic and IBM WebSphere web servers, which provide the same basic functionality to support PeopleSoft applications, including a console interface, secure sockets layer (SSL), and reverse proxy servers (RPS).
Each web server has its own way of accomplishing its functionality, and each adds its own extra features that you might find useful to your PeopleSoft system. This PeopleBook provides supplemental information about configuring and administering the web servers where it has particular relevance to PeopleSoft.
Note. The information in this PeopleBook is not intended to replace any Oracle WebLogic or IBM WebSphere documentation. Always refer to the manufacturer's documentation for detailed information about your web server.
See Also
WebLogic Managed Server Architecture
Verity Search Indexes
A search index is a collection of files that is used during a search to quickly find documents of interest. You build a search index to enable searching on a given set of documents. The set of files that make up the index is a collection. This collection contains a list of words in the indexed documents, an internal documents table containing document field information, and logical pointers to the actual document files.
Important! The Verity search engine is not supported with use of the PeopleSoft Search Framework. If you intend to use the PeopleSoft Search Framework, or any of the features based on the Search Framework, such as Application Search or Keyword Search, you must install Oracle Secure Enterprise Search.
Fields contain metadata about a document. For example, Author and Title might be fields in an index. VdkVgwKey is a special field that identifies each document and is unique to all of the documents in the collection.
Every search index can be modified by changing the configuration files that are associated with the index. These configuration files are known as style files and reside in the style directory under the database directory. A typical configuration of style files define fields for a particular index.
PeopleSoft software supports these types of search indexes:
Record-based indexes.
Record-based indexes are used to create indexes of data in PeopleSoft tables. For example, if the PeopleSoft application has a catalog record that has two fields (Description and PartID), you can create a record-based index to index the contents of the Description and PartID fields.
HTTP spider indexes.
HTTP spider indexes index a web repository by accessing the documents from a web server. You typically specify the starting uniform resource locator (URL). The indexer walks through all documents by following the document links and indexes the documents in that repository. You can control to what depth the indexer should traverse.
File system indexes.
File system indexes are similar to HTTP spider indexes, except that the repository that is indexed is a file system. You typically specify the path to a file directory, then the indexer indexes all documents within that folder. HTTP spider indexes and file system indexes are sometimes collectively referred to as spider indexes. The indexer recognizes a wide variety of document formats, such as Word or Excel documents. Any document in an unknown format is skipped by the indexer.
See Also
Configuring Verity Search and Building Verity Search Indexes
PeopleSoft Configuration ManagerPeopleSoft Configuration Manager is a Microsoft Windows application that simplifies development workstation administration by enabling you to adjust PeopleSoft registry settings from a central location. You can set up one development workstation to reflect the environment at your site, then export the configuration file, which can be shared among other workstations. You can also define separate profiles for connecting to different PeopleSoft databases.
Note. The PeopleSoft Configuration Manager applies only to development environment workstations, such as workstations used to launch Application Designer and Data Mover on Windows.
PeopleSoft configuration parameters are grouped on the Configuration Manager pages according to the function, feature, or tool that they control, including:
Startup settings.
Display settings.
Crystal report and Business Interlink settings.
Trace settings.
Workflow settings.
Remote call settings.
Developer workstations.
Importing and exporting environment settings.
Defining configuration profiles.
See Also
Using PeopleSoft Configuration Manager
PeopleTools UtilitiesThe PeopleTools utilities are a set of various configuration and administration interfaces that serve as a browser-based method of setting numerous system settings. These utilities, most of which are available through the PeopleTools Utilities menu, provide the ability to configure, maintain, or launch a wide range of features, including:
The System Information page.
The message catalog.
The spell check dictionary.
Translate values.
Application server caching.
SQR customization.
Table management and sharing.
Backward compatibility.
Remote database connection.
File attachments.
Stored URLs.
Mobile data synchronization (deprecated).
Update tracking.
Platform-specific database features.
Database auditing.
International settings.
Optimization utilities.
PeopleSoft Ping.
See Also
Tracing and DebuggingYou can use the PeopleCode Debugger to interactively debug a PeopleCode program's configurations of a two-tier connection to the database or a three-tier connection to the database. You can temporarily override the PeopleSoft Configuration Manager trace settings for PeopleCode and SQL programs.
See Also
Tracing, Logging, and Debugging
Jolt Configuration OptionsWith Jolt, PeopleSoft provides the options of configuring load balancing, session pooling, domain connection passwords, and (for some special configurations) Jolt Internet Relay. Load balancing enables you to route requests to servers according to the ability of a server to handle a given request load. Powerful, dedicated servers can take a higher load while less powerful servers can take a lighter load. Session pooling enables user sessions to share web server connections, which is a more efficient use of system resources. The domain connection password enables you to add a connection password to the session between the PeopleSoft Internet Architecture and the application server. Jolt Internet Relay enables you to route connections from one web server to another, perhaps through a fire wall, for specific configuration or security needs.
See Also
Working with Jolt Configuration Options
Timeout SettingsThis appendix lists the delivered default timeout settings for the web server, application server, PeopleSoft Process Scheduler, search servers, and PeopleSoft Internet Architecture (PIA).
See Also
System and Server Administration ImplementationThe functionality of system and server administration for your PeopleSoft applications is delivered as part of the standard installation of PeopleTools, which is provided with all PeopleSoft products.
Several activities must be completed before you administer the system and servers for your implementation:
Install PeopleTools according to the installation guide for your database platform and operating system.
Install your PeopleSoft application according to the installation guide for your database platform and application.
Establish a user profile that gives you access to the tools, pages, and processes that you'll use.
Other Sources of Information
In addition to implementation considerations presented in this section, take advantage of all PeopleSoft sources of information, including the installation guides, release notes, PeopleBooks, and Red Papers.
See Also
System and Server Administration Preface
PeopleTools 8.52: Getting Started with PeopleTools
