| Skip Navigation Links | |
| Exit Print View | |
			Oracle Solaris 11.1 Desktop Administrator's Guide Oracle Solaris 11.1 Information Library |
1. Administering the Oracle Solaris Desktop
2. Managing User Preferences With GConf
9. Overview of the Yelp Help Browser
10. Improving the Performance of the Oracle Solaris Desktop System
11. Disabling Features in the Oracle Solaris Desktop System
The XML file for each help system manual has an associated Open Source Metadata Framework (OMF) file. The OMF file contains information about the manual that is used by the help browser. OMF files have a .omf extension.
When you install an application, the OMF file is copied to the /usr/share/omf/application-name directory. If a help document has an associated OMF file, users can access the help document from the help browser. OMF files contain the following information about help documents:
Location of the XML file for the help document
Title of the help document
Subject category to which the help document belongs
