Using Relevance Ranking Modules
About relevance ranking
You use relevance ranking to control the order in which record search results are displayed to the end-user.
Creating ranking modules
Ranking modules are selected from a stock list of modules. The Static and Phrase modules both take parameters.
Modifying ranking modules
Edit ranking modules from the Relevance Ranking Modules editor, in the Search Interface editor.
Deleting ranking modules
Delete ranking modules from the Relevance Ranking Modules editor.
Changing the order of ranking modules
Select and move modules as needed from the Relevance Ranking Modules editor.
Editing Static module parameters
Edit static module parameters from the Relevance Ranking Modules editor.
Editing Phrase module parameters
Edit phrase modules parameters from the Relevance Ranking Modules editor.
Recommended relevance ranking strategies
Relevance ranking contains a rich set of features that should be used advisedly.
Ranking Modules in Detail
