When you type this Oracle ILOM command:
-> show /System/Cooling
the output under Properties includes the following lines:
installed_power_supply_fans = Not Supported max_power_supply_fans = Not Supported
Workaround: Type the following command to display accurate information about installed power supply fans:
-> show /SYS -l all type==?Fan? value
